Local Time 06:40 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CRC16 Checksum MMBasic
edu001
Posted: 11:51pm 22 Jul 2014
Hi
I need to to a CRC16 Checksum calculation on my output string in MMBasic
Can someone point me in the right direction, I have searched and cannot find any reference to this at all
halldave
Posted: 12:28am 23 Jul 2014
ok found some code needs to be converted
DEFINT A-Z
DECLARE SUB CRC16 (Byte%)
DIM SHARED TableLow(0 TO 255)
DIM SHARED TableHi(0 TO 255)
CLS
FOR I = 0 TO 255 ' Initialize the lookup tables
READ TableLow(I)
NEXT I
FOR I = 0 TO 255
READ TableHi(I)
NEXT I
' just a few lines for test
Lo = 0: Hi = 0 'Initialize CRC to 00 00 (start new)
T! = TIMER
FOR Byte = 1 TO 30000 'Calc CRC for 30000 characters
Char = Byte MOD 256 'Get character
CRC16 Char 'Calc into CRC
NEXT Byte
PRINT TIMER - T! 'Print how long it took
' Were done Hi & Lo contain the result
' Hi = High byte of 16 bit CRC
' Lo = Low byte of 16 bit CRC
END
DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41
DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40
DATA &H00,&HC0,&HC1,&H01,&HC3,&H03,&H02,&HC2
DATA &HC6,&H06,&H07,&HC7,&H05,&HC5,&HC4,&H04
DATA &HCC,&H0C,&H0D,&HCD,&H0F,&HCF,&HCE,&H0E
DATA &H0A,&HCA,&HCB,&H0B,&HC9,&H09,&H08,&HC8
DATA &HD8,&H18,&H19,&HD9,&H1B,&HDB,&HDA,&H1A
DATA &H1E,&HDE,&HDF,&H1F,&HDD,&H1D,&H1C,&HDC
DATA &H14,&HD4,&HD5,&H15,&HD7,&H17,&H16,&HD6
DATA &HD2,&H12,&H13,&HD3,&H11,&HD1,&HD0,&H10
DATA &HF0,&H30,&H31,&HF1,&H33,&HF3,&HF2,&H32
DATA &H36,&HF6,&HF7,&H37,&HF5,&H35,&H34,&HF4
DATA &H3C,&HFC,&HFD,&H3D,&HFF,&H3F,&H3E,&HFE
DATA &HFA,&H3A,&H3B,&HFB,&H39,&HF9,&HF8,&H38
DATA &H28,&HE8,&HE9,&H29,&HEB,&H2B,&H2A,&HEA
DATA &HEE,&H2E,&H2F,&HEF,&H2D,&HED,&HEC,&H2C
DATA &HE4,&H24,&H25,&HE5,&H27,&HE7,&HE6,&H26
DATA &H22,&HE2,&HE3,&H23,&HE1,&H21,&H20,&HE0
DATA &HA0,&H60,&H61,&HA1,&H63,&HA3,&HA2,&H62
DATA &H66,&HA6,&HA7,&H67,&HA5,&H65,&H64,&HA4
DATA &H6C,&HAC,&HAD,&H6D,&HAF,&H6F,&H6E,&HAE
DATA &HAA,&H6A,&H6B,&HAB,&H69,&HA9,&HA8,&H68
DATA &H78,&HB8,&HB9,&H79,&HBB,&H7B,&H7A,&HBA
DATA &HBE,&H7E,&H7F,&HBF,&H7D,&HBD,&HBC,&H7C
DATA &HB4,&H74,&H75,&HB5,&H77,&HB7,&HB6,&H76
DATA &H72,&HB2,&HB3,&H73,&HB1,&H71,&H70,&HB0
DATA &H50,&H90,&H91,&H51,&H93,&H53,&H52,&H92
DATA &H96,&H56,&H57,&H97,&H55,&H95,&H94,&H54
DATA &H9C,&H5C,&H5D,&H9D,&H5F,&H9F,&H9E,&H5E
DATA &H5A,&H9A,&H9B,&H5B,&H99,&H59,&H58,&H98
DATA &H88,&H48,&H49,&H89,&H4B,&H8B,&H8A,&H4A
DATA &H4E,&H8E,&H8F,&H4F,&H8D,&H4D,&H4C,&H8C
DATA &H44,&H84,&H85,&H45,&H87,&H47,&H46,&H86
DATA &H82,&H42,&H43,&H83,&H41,&H81,&H80,&H40
SUB CRC16 (Byte)
SHARED Hi, Lo
Temp = Byte XOR Lo
Lo = TableLow(Temp) XOR Hi
Hi = TableHi(Temp)
END SUB
Edited by halldave 2014-07-24
edu001
Posted: 07:24pm 23 Jul 2014
Thanks for the reply I really did not want to use tables that method is quite slow, Im sure someone must have done this
Posted: 08:56pm 23 Jul 2014
The table method is ofter a lot quicker than calculations.
This is a method I have used (but not in MM Basic).
Procedure.l calcCRC(*LineBuffer, PktSize.l)
Protected i.l, j.l, CRC.l
CRC = 0
For i = 0 To PktSize-1
CRC= CRC ! (PeekA(*LineBuffer+i) << 8)
For j = 1 To 8
If (CRC & $8000)
CRC = (CRC << 1) ! $1021
Else
CRC = CRC << 1
EndIf
CRC = CRC & $FFFF
Next j
Next i
ProcedureReturn CRC
EndProcedure
One big problem is there are a number of CRC16 methods to chose from. You do need an example string and CRC that your device needs to make sure that you are using the correct one.
Posted: 09:24pm 23 Jul 2014
A table is usually just to speed things up - typical trade-off speed vs space.
If speed doesn't matter then a short loop is usually the alternative (but may be too slow in MMBasic).
IIRC, there are multiple 16-bit CRCs but only one known as CRC-16.
(edit: haha, not as such! see wikipedia etc)
Be sure to get the initial value right (often all 1s or 0s) as all others flow from it.
JohnEdited by JohnS 2014-07-25
edu001
Posted: 10:12pm 23 Jul 2014
Thanks for the reply's the one I am after is CRC16_CCITT
TassyJim what did you use that in
Frank N. Furter
Posted: 11:56pm 23 Jul 2014
I need a CRC-Check too!
I found this code in an old thread:
Function CalcolaCRC (buf() As Byte, Nbyte As Integer) As Integer
Dim i As Integer
Dim j As Integer
Dim wCrc As Integer
Const CRC_PRESET = &HFFFF
Const CRC_POLYNOM = &H8408
wCrc = CRC_PRESET
For i = 0 To Nbyte - 1
wCrc = wCrc Xor buf(i)
For j = 0 To 7
If wCrc And 1 Then
wCrc = ((Int(wCrc / 2) And &H7FFF) Xor CRC_POLYNOM)
Else
wCrc = Int(wCrc / 2) And &H7FFF
End If
Next
Next
CalcolaCRC = wCrc
End Function
Can anybody test if this code works on Maximite/Micromite? I think it needs only a small adaption. (I am not able to check if this code works correct...)
Thanks!
Frank
memberx
Posted: 12:47am 24 Jul 2014
I have a SUB code for 16 Bit CRC calculation that returns CRC as Low and High Byte.
Tested on Maximite for specific application.
What is your application?
Frank N. Furter
Posted: 03:17am 24 Jul 2014
I want to use the µMite as I2C-slave and must guarantee that the transmitted data is not corrupt.
Frank
edu001
Posted: 04:46am 25 Jul 2014
memberx
Could you could pm me regarding your code
