Local Time 12:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : which terminal?
BobDevries
Posted: 05:58pm 22 Jul 2014
Hi all,
I've looked through the manual (v4.5) but found no answer:
Is there currently a way for an MMBasic programme to know whether it is "talking" to a USB terminal (Tera Term) or the internal keyboard/display?
We currently have MM.DEVICE$, so maybe MM.TERMINAL could be added to return (say) 0 for internal or 1 for external?
Regards, Bob Devries
Dalby, QLD, Australia
Bob Devries
Posted: 07:23pm 22 Jul 2014
You could monitor the USB 5V supply and if it is there, you are 'possibly' using the USB. If the 5V is not there, it is probably safe to say that you are using the on-board keyboard/VGA.
BobDevries
Posted: 08:22pm 22 Jul 2014
Hi Jim,
Is it possible to monitor the USB supply without modifying the MM?
Sorry, I omitted to mention I'm using a Mono MM.
Bob Devries
Posted: 08:56pm 22 Jul 2014
There should be a diode between the +5V pin on the USB connector and the input to the 3.3V regulator.
Put a resistor, about 1k, between the USB connector side of the diode and a spare input on the maximite. I would use a voltage divider if not using a 5V tolerant pin.
This will let you know when 5V is supplied via the USB but there is no easy way to know if you have your terminal program running.
