Local Time 12:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS18B20 Space Problem
edu001
Posted: 08:33am 22 Jul 2014
Hi
I am using a MicroMite to build a GPS Tracker with the DS18B20 Temp Sensor
The problem I have is that the temp printout has a space before the value, I cannot parse the data unless I remove it
Any Ideas?
jman
Posted: 09:21am 22 Jul 2014
Not quite sure want you are trying to do
Could you post your code so we can help ?
Maybe this bit below will help
Temp = DS18B20(14)
Temp$ = Str$(Temp)
If Int(Val(Temp$)) < 10 Then Temp$ = " " + Temp$
Temp$ = Left$(Temp$,2) + "." + Str$(Int((Temp-Int(Temp))*10))
Print Temp$
Jman
Posted: 09:29am 22 Jul 2014
Assuming value is in a string called Tdata$, then one way to strip a potential leading space is with:
IF LEFT$(Tdata$,1,1)=" " THEN
Tdata$=RIGHT$(Tdata$,2,(LEN(Tdata$)-1))
ENDIF
Another way is to convert string to value with the VAL command. I don't remember MMBasic having a TRIM command (or LTRIM), and don't currently have access to a user manual to check.
Not sure if FORMAT command has a syntax that may work too.
Above should give you something to go on . . . .
WW
edu001
Posted: 11:53pm 22 Jul 2014
Thanks I will try the suggested solutions later I will also post the code
edu001
Posted: 07:34pm 23 Jul 2014
Fixed now B20$ = STR$(DS18B20(15))
