Local Time 12:28 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Good USB Charger Monitor Plugin off ebay
Ray B
Posted: 03:07am 09 Jul 2014
Found this good product for monitoring USB charging phones, tablets etc
less than $3 on ebay and has internal 4 x 7 segment display that toggles every couple of seconds between current and voltage
http://www.ebay.com/itm/310983755607?ssPageName=STRK:MEWNX:I T&_trksid=p3984.m1439.l2649
Enjoy
RayB from Perth WA
G8JCF
Posted: 08:30am 09 Jul 2014
Amazing value for money, thanks for the tip
73
Peter
The only Konstant is Change
Posted: 01:15pm 09 Jul 2014
I have one and I tapped across the current resistor (0.05 ohms) so that I could monitor the current with an external meter. I find that better when looking for pulses.
Eventually, I intend to make it into a current logger (with a micromite naturally).
