Local Time 06:22 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : question on keyboard (or keys)
f1fco
Posted: 10:08am 28 Jun 2014
I want to use the CGKEYCHIP1 - PS/2 Keyboard Chip
like this, here : http://www.circuitgizmos.com/products/cgkeychip1/cgkeychip1. shtml
but HOW to make a keyboard ? with custom keys
I want to write my own labels under the caps... to custom a little keyboard (10 to 20 keys)
can you help me to found this keys ?
thank you
Pierre, from Nimes, south of France
73s de F1FCO
f1fco
Posted: 10:10am 28 Jun 2014
the site is here :
73s de F1FCO
f1fco
Posted: 10:11am 28 Jun 2014
73s de F1FCO
f1fco
Posted: 10:12am 28 Jun 2014
cgkeychip1. shtml !!!
erase the space between dot and shtml
73s de F1FCO
BobD
Posted: 10:31am 28 Jun 2014
Pierre
Use the hyperlink button to add links. It is the 4th button from the left on the toolbar.
Frank N. Furter
Posted: 07:15am 29 Jun 2014
Hi Pierre,
take a look on my Keyboardemulator
It works very fine on PS/2 and you can generate ANY keystroke!!!
(There is a HT82K628A from HOLTEK available which can only PS/2 which doesn't need an quartz... - it's a very simple circuit!!!)
Frank
Frank N. Furter
Posted: 07:33pm 29 Jun 2014
I used in the past this Button:
You can open it and you can put any (laser) printed paper (with transparent foil above) instead of the original plate in it.
Frank
Posted: 07:58pm 29 Jun 2014
The CG keyboard chip is for use with the MaxiMite series of computers - it will not function as a keyboard if you connect it to a PC or other full-size computer.
CG has tested that, and a PC will not respond to this chip as a keyboard, as it is not a true keyboard controller, but an emulator.
This works fine on the MM, but just don't expect to be able to plug this into a PC...
@ Frank-N-Furter - I have the 628A's, that don't need the crystal, and these are the ones I could not make work. I might have to try again....
Frank N. Furter
Posted: 08:17pm 29 Jun 2014
Hi Grogster,
I have no experience with the HT82K628A, I used only the HT82K629A (and this one works very fine).
Did you used the correct value for the oscillator resistor (58,3KOhm - I think the timing of the oscillator is very important) and did you used a FERRIT on VDD? I would try to connect the resistor on the µC-side of the FERRIT OR on the power side...
I hadn't any problems with the HT82K629A on USB AND PS/2...
Frank
Posted: 08:57pm 29 Jun 2014
Hi there. I tried to get as close to the 58k3 as possible, but perhaps I should have used a resistor and a trimmer, and set that to exactly 58k3 before putting the chip in....(i did not do THAT)
I might have another play with these chips, as I have nine more....
Yes, I did use a ferrite bead on VCC as per the datasheet.
EDIT: Just had a quick look at my old attempt - I used a 56k and 2k2 metal-film 1% resitor in series, giving a total of 58k2, which I thought would have been close enough - perhaps not? I will see if I can find the old prototype PCB, and I could always hack an extra 100-ohm 1% resistor in there, and see if we get a response.Edited by Grogster 2014-07-01
f1fco
Posted: 10:19am 30 Jun 2014
thank you Frank for photo and link of the buttons, but item is out of stock
I seach for custom buttom to use it with a maximite via a CG keyboard chip, not with a PC !!!
Pierre
73s de F1FCO
Posted: 01:33pm 30 Jun 2014
Lovely - that's nice to know. At least it should work fine then.
Frank N. Furter
Posted: 07:18pm 30 Jun 2014
Hi Pierre,
you should get the Buttons from:
REICHELT
MOUSER
or
DIGIKEY
Take a search to "Schurter" "1241.1100.7093" on the WEB
Frank
f1fco
Posted: 08:30pm 07 Jul 2014
thank you for answer
also I search for "old" DIGITAST keys
at low prices...
73s from F1FCO, Pierre from Nimes, south of France
73s de F1FCO
