Local Time 15:24 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MAX7219 led display driver
viscomjim
Posted: 07:03am 27 Jun 2014
Hi All,
From the thread "[MicroMite]AD9850 Controller Source Code" - Member Boss has posted some code that I believe needs to have its own thread. The MAX7219 is a very interesting chip and there are several different types of LED displays that are readily available to us uMiters that can add a bit of coolness to our projects. I have seen 8x8 matrix and 8 digit 7 segment displays and there are more. On ebay, they can be had quite reasonably. This chip uses spi communications and Boss has done a bang up job on providing some code that will get me going using this chip with little pain. This is a great example of using SPI to interface with. I pulled up the MAX7219 data sheet and Boss's code side by side on my screen and saw how he is addressing the different registers on the chip to make things happen. Very exciting!!! A BIG THANKS!
I hope I am not out of line repeating Boss's code here. Again, THANKS BOSS!!!!
' MAX7219 LED DISPLAY *
'SPI PINS
RX=1
TX=14
CLK=15
PLOAD=16
SetPin RX, DIN
SetPin TX, DOUT
SetPin CLK,DOUT
SetPin PLOAD,DOUT
Pin(14)=0
Pin(15)=0
PIN9160=0
'----------------------MAIN----------------------------
M7219_INIT
TEST_E
TEST_F
DP 1
RAND_NUM
End
Sub M7219_INIT
AA=SPI(RX,TX,CLK,&H0C00,,,16): Pulse PLOAD,1 'SHUTDOWN
AA=SPI(RX,TX,CLK,&H09FF,,,16): Pulse PLOAD, 0.1 'BCD DECODE ALL DIGITS
AA=SPI(RX,TX,CLK,&H0A08,,,16): Pulse PLOAD, 0.1 'BRIGHT 17/32%
AA=SPI(RX,TX,CLK,&H0B07,,,16): Pulse PLOAD, 0.1 '8 DIGITS
AA=SPI(RX,TX,CLK,&H0F00,,,16): Pulse PLOAD, 0.1 'TESTS OFF
AA=SPI(RX,TX,CLK,&H0C01,,,16): Pulse PLOAD, 1 'RUN
ERASE_ALL
DP 1 ' .
End Sub
Sub ERASE_ALL
Local I,AA
For I=1 To 8
AA=SPI(RX,TX,CLK,&H000F+I*256,,,16): Pulse PLOAD,1
Next I
End Sub
Sub TEST_F
Local AA
AA=SPI(RX,TX,CLK,&H0F01,,,16): Pulse PLOAD,1
Pause 3000
AA=SPI(RX,TX,CLK,&H0F00,,,16): Pulse PLOAD,1
End Sub
Sub TEST_E
Local I,J,AA
For I=1 To 8
For J=1 To 15
AA=SPI(RX,TX,CLK,I*256+J,,,16): Pulse PLOAD,0.1
Pause 200
Next J
Pause 300
Next I
End Sub
Sub DP (T)
Local AA
If T<1 Or T>8 Then T=1
AA=SPI(RX,TX,CLK,T*256+&H8F,,,16): Pulse PLOAD,0.1
End Sub
Sub RAND_NUM (RN)
Local I,J,RN$,B
Randomize Timer
ERASE_ALL
RN=Rnd()*1000000
RN$=Str$(RN)
J=Len(RN$)
For I=1 To J
A$=Mid$(RN$,I,1)
C=Val(A$)
AA=SPI(RX,TX,CLK,(J-I+1)*256+C,,,16): Pulse PLOAD,0.1
Next I
' Print RN;RN$
Pause 1000
Loop
End Sub
viscomjim
Posted: 02:20pm 27 Jun 2014
Upon further examination of this code, it was written for the Maximite series. So if you want to use this on a uMite, there are a few changes needed, such as the pins being used are very specific to both the 28 and 44 pin uMites. Also, the spi channel must first be opened, and also closed. Take a look at page 66 of the uMite manual to see the changes necessary. Sorry to jump the gun. When my spi displays arrive, I will post my results and subsequent code changes.
Frank N. Furter
Posted: 09:44pm 15 Jul 2014
Hi All,
special thanks to Member Boss and to Viscomjim for sharing this code. I adapted the code successful to White Wizzards 44pin Micromite module:
' MAX7219 LED DISPLAY for 44pin µMite *
'SPI PINS
SPI OPEN 3000000, 3, 16
'RX not needed
'TX=20
'CLK=14
PLOAD=5
SetPin PLOAD,DOUT
M7219_INIT
TEST_E
TEST_F
DP 1
RAND_NUM
End
Sub M7219_INIT
AA=SPI(&H0C00): Pulse PLOAD,1 'SHUTDOWN
AA=SPI(&H09FF): Pulse PLOAD, 0.1 'BCD DECODE ALL DIGITS
AA=SPI(&H0A08): Pulse PLOAD, 0.1 'BRIGHT 17/32%
AA=SPI(&H0B07): Pulse PLOAD, 0.1 '8 DIGITS
AA=SPI(&H0F00): Pulse PLOAD, 0.1 'TESTS OFF
AA=SPI(&H0C01): Pulse PLOAD, 1 'RUN
ERASE_ALL
DP 1 ' .
End Sub
Sub ERASE_ALL
Local I,AA
For I=1 To 8
AA=SPI(&H000F+I*256): Pulse PLOAD,1
Next I
End Sub
Sub TEST_F
Local AA
AA=SPI(&H0F01): Pulse PLOAD,1
Pause 3000
AA=SPI(&H0F00): Pulse PLOAD,1
End Sub
Sub TEST_E
Local I,J,AA
For I=1 To 8
For J=1 To 15
AA=SPI(I*256+J): Pulse PLOAD,0.1
Pause 200
Next J
Pause 300
Next I
End Sub
Sub DP (T)
Local AA
AA=SPI(T*256+&H8F): Pulse PLOAD,0.1
End Sub
Sub RAND_NUM (RN)
Local I,J,RN$,B
Randomize Timer
ERASE_ALL
RN=Rnd()*1000000
RN$=Str$(RN)
J=Len(RN$)
For I=1 To J
A$=Mid$(RN$,I,1)
C=Val(A$)
AA=SPI((J-I+1)*256+C): Pulse PLOAD,0.1
Next I
' Print RN;RN$
Pause 1000
Loop
End Sub
Thanks again
Frank
boss
Posted: 06:25am 18 Jul 2014
I'm glad you found this code usable,
Thank you
boss
Cyber
Posted: 11:38pm 03 Jul 2019
  boss said  I'm glad you found this code usable
Thanx a lot! The code helped me to figure out how things work.
I also modified the code for use with 8x8 matrix.
Below is my code and video of how it works.
Hope this also helps someone.
Datasheet: 2019-07-04_093638_MAX7219-MAX7221.pdf
Video: https://youtu.be/6bcrovHx6Os
' MAX7219 LED DISPLAY * 8X8 MATRIX
'SPI PINS
RX=1 ' MISO, DIN
TX=14 ' MOSI, DOUT
CLK=15 ' SCLK, CLOCK
PLOAD=16 ' SS, CS
SETPIN RX, DIN
SETPIN TX, DOUT
SETPIN CLK,DOUT
SETPIN PLOAD,DOUT
PIN(TX)=0
PIN(CLK)=0
PIN(PLOAD)=0
M7219_INIT
TEST_F 'DISPLAY TEST MODE
TEST_E 'ALL LED ON/OFF COMBINATIONS
RAND_LINE 'DRAW RANDOM PATTERNS
ANIM_ARROW 'ANIMATION
ERASE_ALL 'CLEAR SCREEN
END
SUB M7219_INIT
AA=SPI(RX,TX,CLK,&H0C00,,,16): PULSE PLOAD,1 'SHUTDOWN MODE ON
AA=SPI(RX,TX,CLK,&H0900,,,16): PULSE PLOAD, 0.1 'NO DECODE
AA=SPI(RX,TX,CLK,&H0A08,,,16): PULSE PLOAD, 0.1 'BRIGHT 17/32
AA=SPI(RX,TX,CLK,&H0B07,,,16): PULSE PLOAD, 0.1 'SCAN-LIMIT ALL
AA=SPI(RX,TX,CLK,&H0F00,,,16): PULSE PLOAD, 0.1 'TESTS OFF
AA=SPI(RX,TX,CLK,&H0C01,,,16): PULSE PLOAD, 1 'SHUTDOWN MODE OFF
END SUB
SUB ERASE_ALL
LOCAL I,AA
FOR I=1 TO 8 'FOR EACH LINE
AA=SPI(RX,TX,CLK,I*256,,,16): PULSE PLOAD,1 'CLEAR LINE
NEXT I
END SUB
SUB TEST_F
LOCAL AA
AA=SPI(RX,TX,CLK,&H0F01,,,16): PULSE PLOAD,1 'DISPLAY TEST MODE ON
PAUSE 3000
AA=SPI(RX,TX,CLK,&H0F00,,,16): PULSE PLOAD,1 'DISPLAY TEST MODE OFF
END SUB
SUB TEST_E
LOCAL I,J,AA
FOR I=1 TO 8
FOR J=0 TO 255
AA=SPI(RX,TX,CLK, I*256+J ,,,16): PULSE PLOAD,0.1
PAUSE 10
NEXT J
PAUSE 500
NEXT I
PAUSE 1000
END SUB
SUB RAND_LINE
LOCAL F,I,R,AA
FOR F = 1 TO 50
FOR I = 1 TO 8
R = CINT(RND() * 255)
AA = SPI(RX, TX, CLK, I*256 + R, , , 16) : PULSE PLOAD, 0.1
NEXT I
PAUSE 100
NEXT F
END SUB
SUB ANIM_ARROW
LOCAL D(7), F, K, R, N, AA
D(0) = &B00010000
D(1) = &B00111000
D(2) = &B01111100
D(3) = &B11111110
D(4) = &B00111000
D(5) = &B00111000
D(6) = &B00111000
D(7) = &B00000000
FOR F = 1 TO 10
FOR K = -1 TO 6
FOR R = 1 TO 8
N = R + K
IF N > 7 THEN N = N - 8
AA = SPI(RX, TX, CLK, R*256 + D(N), , , 16) : PULSE PLOAD, 0.1
NEXT R
PAUSE 100
NEXT K
NEXT F
END SUB
Edited by Cyber 2019-07-05
Posted: 05:41am 04 Jul 2019
timely!
I have one of these chips in a design for an electronic dial in a Harley Davidson FDX bike (for a customer).
I am using it not as a matrix controller, but simply as a display adapter for 24 individual LEDs (rev counter) and a clock (4 x seven segment) module.
The board is all made up but not tested and the code is embryonic because a key part of the head unit is being supplied from a crowd-funded source which is typically, running late.
This old thread, which I was not aware of, and the demo code will prove useful as I progress.
thanks for bringing this up
On the subject of that beeline thing, I had thought of doing it all with a MM... GPS... bit of maths... one of those round LCDs... but it is quite a complex beast - it isn't simply a bearing and distance but is a full-blooded navi-com just with a simplistic (non-map based) display. If it was simply a "your destination is 2 miles that-a-way" it would have been a piece of cake, but that could take the rider over a cliff... the beeline knows about the roads. The memory alone for that is way over the abilities of a mite and a GSM connection can't be guaranteed to let google do it. It is possible with their API on tiny systems - easily a mite, but you need network all the time.
Edited by CaptainBoing 2019-07-05
Posted: 12:11am 05 Jul 2019
Hi viscomjim, cyber,
Some time ago Curtis Pratt and I came up with the Mik-Matrix which uses 2 x max7219 per module and creates a 3 colour matrix and moving message board..
Curtis taught himself C to get the speed required to manipulate the data and came up with a very nice lump of code..
Kind Regards,
Edit ***
The sample vid clips look more jerky than the actual module. It was hard to video showing the brilliant colours. (Read near impossible)
Mik
Edit 2 ***
I am happy to send you a few PCB if you want to play but I am on holidays for another week.
MikEdited by bigmik 2019-07-06
Justplayin
Posted: 05:36pm 05 Jul 2019
Since the TBS search feature is currently offline I can not point to the original thread I posted these to. These are my original efforts with the MAX7219 and mono-matrix 8x8 displays.
Micromite 170 Powered Clock: http://youtu.be/va1OBuAXC0s
Halloween Animation: https://www.youtube.com/watch?v=o5LF-GLEE9w
--Curtis
Cyber
Posted: 06:10pm 05 Jul 2019
  Justplayin said  I can not point to the original thread I posted these to.
Why can't you? You mean this thread?
https://www.thebackshed.com/forum/forum_posts.asp?TID=7916
Justplayin
Posted: 10:47pm 05 Jul 2019
I did not realize I could find old posts using a profile... Learned something new.
Posted: 12:39am 06 Jul 2019
Lads,
I didn’t know search was off line.
Does Gizmo realise it isn’t working.?
Mik
PS.
Enjoying the sun in Mulwala NSW
Edited by bigmik 2019-07-07
BrianP
Posted: 01:09am 06 Jul 2019
@bigmik - see the "forum is ill" sticky post at the very top...
Posted: 01:16am 06 Jul 2019
Thanks Brian,
I usually skip the stickies to read the micro posts...
Shows I should’ve more attentive to things..
Mik
BrianP
Posted: 01:27am 06 Jul 2019
Join the club...
Cyber
Posted: 04:20am 06 Jul 2019
  Justplayin said   I did not realize I could find old posts using a profile... Learned something new.
That's how I found it. :)
Also you can type in google:
site:www.somesite.com text to find
For example: https://www.google.com/search?q=site:www.thebackshed.com+8x8+matrix+led
Posted: 06:40am 06 Jul 2019
Now that is new (for me) live & learn - Thanks!
