Local Time 12:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C help for Micromite?
Oldbitcollector
Posted: 06:24pm 03 Jun 2014
Can someone provide some examples of how to use the I2C commands with the Micromite?
I've got some code for reading the Wii controller in another language and would like to convert it over. I tend to learn by example.
Any help would be appreciated.
Jeff
My Propeller/Micromite mini-computer project.
Posted: 06:59pm 03 Jun 2014
If you can provide the code in the other language, we should be able to help with the conversion.
As an example, this code controls the alarm functions on the PCF8563 RTC.
dim RTCbuffer(16)
PCF8563address = &h51
function setRTCint(count,scale)
' scale: 2 = seconds, 3 = minutes
local t_ctrl
t_ctrl = 128 + scale
I2C write PCF8563address,0,1, &H00 ' set the starting address for a read
i2c read PCF8563address,0,16,RTCbuffer(0)
I2C write PCF8563address,0,2, &H01, &H11
I2C write PCF8563address,0,3, &H0E, t_ctrl, count' timer control register
setRTCint=RTCbuffer(1)
end function
function setRTCalarm(hour, minute,day,WkDay)
local alarmH,alarmM,alarmD,alarmWD
alarmH=int(hour/10)*16+(hour mod 10)
'alarmH=128 ' not used (once an hour)
alarmM=int(minute/10)*16+(minute mod 10)
'alarmD=int(day/10)*16+(day mod 10)
alarmD=128 ' not used (every day)
'alarmWD=WkDay
alarmWD=128 ' not used (every day)
I2C write PCF8563address,0,2, &H01, &H12
I2C write PCF8563address,0,5, &H09, alarmM, alarmH,alarmD, alarmWD
end function
FUNCTION setRTC()
' set the RTC to MicroMite time
local newtime$, year, month, day, hour, min, sec
newtime$= time$ ' make a copy to stop time changing while we set the clock
year = val(mid$(date$,9))
month = val(mid$(date$,4,2))
day = val(mid$(date$,1,2))
hour = val(mid$(newtime$,1,2))
min = val(mid$(newtime$,4,2))
sec = val(mid$(newtime$,7,2))
rtc settime year,month,day,hour,min,sec
END FUNCTION
function clearRTCalarm()
' two bits indicate if alarm or timer triggered the interupt
' we clear them both
local x
i2c read PCF8563address,0,2,RTCbuffer(0)
x = (RTCbuffer(1) and &H13)
I2C write PCF8563address,0,2, &H01, x
clearRTCalarm=RTCbuffer(1) and &H0C ' 8 = alarm and 4 = timer
end function
You really need to start with the data sheets for the module you are talking to.
You should find some clues if you do a search of the forum for "numchuck".
The code will need to be changed to suit the new I2C commands.
JimEdited by TassyJim 2014-06-05
Posted: 08:39pm 03 Jun 2014
Hi Jeff,
I posted this Thread a couple of days ago.
I modified Jman's modifications of `letsmakerobots.com' code to use the uMite commands then modified it to talk to two different I2C LCD modules.
Works really well and not too difficult to understand.
Edited by bigmik 2014-06-05
Bill.b
Posted: 09:19pm 03 Jun 2014
This is picaxe code for the wii classic controller
Unfortunately I have dismantled my wii controller to use the parts
in other project, so I will not be trying to migrate it across.
[code]
' Program to read data form a Wii Classic Controller into a picaxe 28X2.
' Bill Brown Bill.b 29th July 2013
' I have tested the program with a 40X2 and it worked OK. The program does not work correctlly with M2 chips
' Some more work is required for M2s
' The Wii Receiver module required a 3.3volt supply.
' In my test unit i derived the 3.3v by connection two IN4001 diodes in series to the 5v supply giving approximatly 3.4v.
' 4k7 pullup reistors are unsed on the SCL and SDA - Connected to the +3.4v supply
' Data format for the 6 bytes of data from the Wii Classic Controller (WiiByte0 - 5)
'|Byte | Bit |
'| | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
'| 0 | RX<4:3> | LX<5:0> |
'| 1 | RX<2:1> | LY<5:0> |
'| 2 |RX<0> | LT<4:3> | RY<4:0> |
'| 3 | LT<2:0> | RT<4:0> |
'| 4 | BDR | BDD | BLT | B- | BH | B+ | BRT | 1 |
'| 5 | BZL | BB | BY | BA | BX | BZR | BDL | BDU |
'LX,LY are the left analogue stick, X and Y (0 - 63). RX and RY are the right analogue stick, X and Y (0 - 31).
'LT and RT are the left and right triggers (0 - 31). The left analogue stick has twice the precision of the other stick
' BD(L,R,U,D) are the D-Pad direction buttons. B(ZR,ZL,A,B,X,Y,+,H,-) are the discrete buttons.
'B(LT,RT) are the digital button click of the LT and RT. all Buttons are 0 when pressed.
#picaxe 28x2
setfreq m8
symbol WiiByte0 = b7 'Wii byte 0
symbol WiiByte1 = b8 'Wii byte 1
symbol WiiByte2 = b9 'Wii byte 2
symbol WiiByte3 = b10 'Wii byte 3
symbol WiiByte4 = b11 'Wii byte 4
symbol WiiByte5 = b12 'Wii byte 5
symbol WiiTemp0 = b13 'Wii Temperary storage byte
symbol WiiLeftX = b14 'Left stick X axis 0 - 63
symbol WiiLeftY = b15 'Left stick Y axis 0 - 63
symbol WiiRightX = b16 'Right stick X axis 0 - 31
symbol WiiRightY = b17 'Right stick Y axis 0 - 31
symbol WiiLeftT = b18 'Left trigger 0 - 31
symbol WiiRightT = b19 'Right trigger 0 - 31
i2cslave %010100100, i2cfast_16, i2cbyte 'I2C setup for Wii controller
hi2cout 0,($F0,$55) 'Wii Configuration bytes
pause 10
hi2cout 0,($FB,00) 'Wii Configuration bytes
pause 10
hi2cout 0, ($00) 'Wii Request data
'Main program start here
main:
pause 70
hi2cin 0,(WiiByte0,WiiByte1,WiiByte2,WiiByte3,WiiByte4,WiiByte5) 'Data from Wii Controller
'The following section arranges the data from the Wii bytes 0 - 4 into seperate bytes for used in the program
pause 50
WiiLeftX = WiiByte0 & %00111111 'Left stick X = Bits 0 - 5 of wiibyte0
WiiLeftY = WiiByte1 & %00111111 'Left stick Y = Bits 0 - 5 of wiibyte1
WiiRightX = WiiByte2 & %00011111 'Right stick X = Bits 0 - 4 of wiibyte2
WiiRightY = WiiByte2 & %10000000 'Move bit 7 of wiibyte2 to Right stick Y
WiiRightY = WiiRightY >> 2 'shift right 2 places
WiiTemp0 = WiiByte1 & %11000000 'move bits 6 & 7 of wiibyte1 to temp
WiiRightY = WiiRightY OR WiiTemp0 'Combine temp and right stick Y
WiiRightY = WiiRightY >> 2 'Shift right 2 places
WiiTemp0 = WiiByte0 & %11000000 'move bits 6 & 7 of wiibyte0 to temp
WiiRightY = WiiRightY >> 3 'Shift right 3 places. Right stick Y byte completed
WiiRightT = WiiByte3 & %00011111 'move Right Tigger bits 0 - 5 form wiibyte 3 to wiiRightT
WiiLeftT = WiiByte3 & %11100000 'move left trigger bits 5 - 7 form wiibyte 3 to wiiLeftT
WiiLeftT = WiiLeftT >> 3 'shift right 3 positions.
WiiTemp0 = WiiByte2 & %01100000 'Move Left trigger bits 3 & 4 to temp
WiiLeftT = WiiLeftT OR WiiTemp0 ' combine wiiLeftT and Temp
WiiLeftT = WiiLeftT >> 2 'Shift right 2 positions to complete wiiLeftT byte.
'debug
goto main
[/code]
BillEdited by Bill.b 2014-06-05
viscomjim
Posted: 09:55pm 03 Jun 2014
Hi OBC,
I started playing with the I2C also between 2 uMites. The example in the uMite manual is a very good starting place for this. I had to study it a few times and experiment for a while until it sunk in. It is a great ability for the uMite and once you get the basics, interfacing just about anything can be done. There seems to be a small bug in the slave receive, however there is a work around that does work.
It is shown here I2C slave receive fix
jman
Posted: 10:14pm 03 Jun 2014
Take a look at the thread below Wii numchuck with the original Maximite
http://www.thebackshed.com/forum/forum_posts.asp?TID=4312&KW =wii
Jman
Oldbitcollector
Posted: 03:51am 04 Jun 2014
Wow.
Thank you all for the responses.. Talk about a welcome..
@Jman, That looks like the ticket! I can see the similarities between that code and my existing code and {expletive edited}! the I2C interface looks as sweet as French Silk pie! This little Micromite chip is packs a lot of horsepower.
I'm used to doing jobs like this with a page of code, not two or three commands.
I'll post up some working code as soon as I noodle it out later today.
Jeff
Oldbitcollector
Posted: 06:41pm 04 Jun 2014
As promised.. As someone else may need this thread at some point.
[code]
i2caddr = &h52
DIM RDBuff(255)
I2C open 400,100 ' Enable I2C
I2C write i2caddr,0,2,&hf0,&h55
I2C write i2caddr,0,2,&hfb,&h0
:readwii
I2C write i2caddr,0,1,&h0
I2C write i2caddr,0,6,RDBuff(0)
PRINT " Joy X:";RDBuff(0);
PRINT " Joy Y:";RDBuff(1);
PRINT " AccelX:";RDBuff(2);
PRINT " AccelY:";RDBuff(3);
PRINT " AccelZ:";RDBuff(4);
PRINT " ButtonZ:";(RDBuff(5) AND &h01);
PRINT " ButtonC:";(RDBuff(5) AND &h02)
pause 50
GOTO readwii
[/code]
Edited by Oldbitcollector 2014-06-06
Posted: 06:07pm 05 Jun 2014
I don't have any hardware to test this code but should not line 8 read:
I2C READ i2caddr,0,6,RDBuff(0)
And there is no need to declare such a large array to receive the data. This would be more economical with memory:
DIM RDBuff(5)
