Local Time 11:52 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C issue narrow down
viscomjim
Posted: 12:57pm 29 May 2014
Playing with I2C and am encountering a problem that is very repeatable. I have 2 uMites set up, one as master and one as slave. Both units are up and running with the attached code, using 2 instances of MMedit. I control C the slave and hit run again. No matter what the first byte the master sends (I'm just sending one byte), the slave always has a 2 received. After that, the slave reads the master properly. I never stop the master running the program, just the slave and always get a 2 the first time. If I cycle power on the slave, then it receives the correct byte from the master every time.
I am not sure if I added the code correctly in this post...
Code running on Master:
DO
INPUT "ENTER COMMAND ";CMD
SENDCMD CMD
RCVCMD
LOOP
SUB SENDCMD CMD
I2C OPEN 100, 1000
I2C WRITE &H26, 0, 1, CMD
IF MM.I2C THEN ERROR "Slave did not respond"
I2C CLOSE
END SUB
SUB RCVCMD
I2C OPEN 100, 1000
I2C READ &H26, 0, 1, RCVBCK
PRINT "RECEIVED BACK =";RCVBCK
I2C CLOSE
END SUB
Code running on Slave:
OPTION AUTORUN ON
I2C SLAVE OPEN &H26, 0, 0, WriteD, ReadD
DO
WATCHDOG 1000
LOOP
ReadD:
I2C SLAVE READ 1, CMD, RCVD
PRINT "COMMAND =";CMD;" RECEIVED =";RCVD
IRETURN
WriteD:
SNDBCK = CMD + 1
I2C SLAVE WRITE 1, SNDBCK
IRETURN
Posted: 01:27pm 29 May 2014
WARNING - this is MY interpretation of the problem.
When the SLAVE starts from a cold start, the I2C buffer pointers are equal and pointing to the start of the buffer.
If the slave device interrupts the receiving routine, when the routine restarts, one of the pointers is reset but not both. This causes the apparent extra data.
The solution when you only want one byte is to be prepared to receive more data than you expect and only use the last byte.
I will try to produce a working example later today.
viscomjim
Posted: 01:30pm 29 May 2014
Hi Jim,
Did you ever find a way to clear the buffer after the receive was complete?
viscomjim
Posted: 03:32am 30 May 2014
I am at work now and cannot test this, but, do you think the "clear" command would work for this situation?
viscomjim
Posted: 06:39pm 30 May 2014
It looks like "clear" does not make a difference with I2C.
Posted: 09:10pm 30 May 2014
JIm,
we will have to wait for a fix to the I2C commands.
For now, try the following code for the slave:
option autorun on
dim cmdline(256)
DO
WATCHDOG 1000
LOOP
ReadD:
I2C SLAVE READ 255, CMDline(0), RCVD
CMD=cmdline(RCVD-1)
IRETURN
WriteD:
SNDBCK = CMD + 1
IRETURN
viscomjim
Posted: 02:41am 31 May 2014
Hi Jim,
That is a very clever way to do that. I will load this and report back. I really appreciate you looking at this.
EDIT:
First of all, THAT WORKED!!!! - I ran this several times and here are the results...
Upon power up of the slave, cmd byte comes in properly as before with rcvd being 1. With control C and run, cmd byte comes in properly with random number for rvcd for first use, then rvcd is 1 for any after the first received. After more control C and run, whatever the random number for rvcd was, it increments by 1 each time. So bottom line is, the cmd is correct everytime.
Thanks for your help, hopefully there will be a fix soon, but this will work splendidly for now.Edited by viscomjim 2014-06-01
Posted: 02:36pm 31 May 2014
Good news.
