Local Time 11:52 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Number of lines Full Screen Editor
hitsware
Posted: 09:32am 28 May 2014
Duinomite Mega using Minicom term through usb MM4.4
When I write a routine, I can only get 29 lines before coming to the options (Save etc) accross the bottom. Then it starts scrolling.
This is not even half way down the screen. I don't know if this a function of MM4.4? Full Screen Editor? or Minicom ?
Is there a way to set up for more lines ?Edited by hitsware 2014-05-29
Posted: 12:17pm 28 May 2014
MMBasic Editor for the Maximite/Duinomite is fixed at 36 lines so I expect a setting in Minicom.
(The micromite has the option to change the number of lines)
