Local Time 11:38 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : write to DS3232 rtc with mmbasic
banda
Posted: 04:26pm 22 May 2014
I have had a great time learning from a series of posts in this forum dealing with the above series topic. There is a superb program written by JMAN that I am analysing
at the moment, but am not able to set up a breadboard for it yet.
In his coding he converts the secs, mins, etc to HEX before he writes them to the ds3232. I am under the belief that we must use BCD to write the time to the rtc.
Can JMAN or anyone else put my mind at rest?
It must be obvious that I'm a rank beginner.
Posted: 05:28pm 22 May 2014
I don't have the code you are using to look at, but according to my reading of the datasheet, the DS3232 needs the time data in BCD as you thought.
jman
Posted: 08:18pm 25 May 2014
  Quote  In his coding he converts the secs, mins, etc to HEX before he writes them to the ds3232. I am under the belief that we must use BCD to write the time to the rtc
' Convert to Hex
Sub BCDtoHex TempDec
hex = fix(tempdec / 10) * 16
hex = hex OR ((tempdec / 10) - (fix(tempdec / 10))) * 10
return
Hi
Would be better written as
Tempdec is your decimal value
'Convert Decimal to BCD
Sub DECtoBCD TempDec
BCD = fix(tempdec / 10) * 16
BCD = BCD OR ((tempdec / 10) - (fix(tempdec / 10))) * 10
return
So to convert normal decimal numbers to binary coded decimal
val is your decimal number
BCD=((val/10*16) + (val/10))
The original does indeed work just he labels are rather poor
Jman
