Local Time 05:40 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit V3.4.10
Posted: 11:39am 06 May 2014
Just a small bug fix.
Adding your own help resources was failing to add the final backslash to the file path.
Thanks Bob for finding the bug.
The full version of MMedit can be downloaded for the usual place
http://www.c-com.com.au/MMedit.htm
or the TKN file in the attached ZIP can replace the one on the program folder.
2014-05-06_213838_MMedit.zip
