Local Time 11:38 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WS 2812 led stripe
plasma
Posted: 11:39am 05 May 2014
i have much fun with a Led stripe and an arduino , but i think running this with the micromite
are much moore fun !
What do you think geoff ?
led strip code
and
c code for pic
atmega8
Posted: 12:51pm 05 May 2014
Toggling portpins in Sub microseconds will be to fast for mmbasic...
plasma
Posted: 01:07pm 06 May 2014
i mean an internal routine which shifting the bits from the ledstring to a port with the right timing.
such like ledshiftout,ledstring,ledcount
the ledstring contains the r,g,b data for each led ( micromite can maybe support a 85 led stripe , because
the max length of a string is here 255.
plasma
Posted: 09:11am 12 May 2014
finally it works . its fantastic to see a basic powered led stripe
viscomjim
Posted: 10:06am 12 May 2014
Would love to see it, can you post a upload on youtube or something like that?
plasma
Posted: 10:27am 12 May 2014
led stripe Edited by plasma 2014-05-13
Frank N. Furter
Posted: 07:18pm 12 May 2014
Hi Plasma,
would you paste your code here? ...I have a two or three meter stripe here but not enough time to test it...
Thanks!
Frank
Posted: 08:12pm 12 May 2014
Hi Plasma, that looks good.
Would using SPI for controlling those led strips not be a possible way to get the needed speed from Basic?
btw, i saw your video controlling a stepper motor with a micromite.
I have the same ones here, would you be able to share your code?
plasma
Posted: 09:03pm 12 May 2014
Hi ,
At the moment it use a modified MMbasic
for the bitbanging .
To get a constant timing i forbid interrupt .
This shuts also the video down .
The delays are solved with a different loop
for 1 or 0 bit.
All in all i think a modified spi routine is
much better !
The ledcolour are stored in a string .
I modified the strings to get new colours with
a basic routine .
The Frame rate depends on the lenght of the
String or Led count.
To get much moore as 80 led i have an idea
but this needs time .
A left or rightshifting is easy todo also.
This is all !
If iam able to solve this with spi i will send the
Code to Geoff.
Maybe he put this in , also on the Micromite !
All other codes from my videos needs to be resurrectet!
I will take a look !
Gtx
plasma
Posted: 11:24am 18 May 2014
134 Led
same without Pause 20ms
no array yet
no spi yet
@ I think i have the micromite source for the stepper motors
gtx
