Local Time 05:41 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Firmware V4.5C - New Version
Posted: 07:33pm 01 May 2014
A new version of MMBasic for the Micromite is available for download from http://geoffg.net/micromite.html#Downloads
This version fixes a few bugs, one of which could, in rare cases, cause the Micromite to partially erase its firmware (ie, "brick" itself). This was serious enough to warrant a new release.
For details of the bug check this thread: http://www.thebackshed.com/forum/forum_posts.asp?TID=6512&PN =1
Thanks very much to TZAdvantage who found the bug and documented it so well that the fix was easy. He also put in many hours verifying the fix - a great effort.
To load the new version you will need a programmer such as the PICKit 3. If you do not have a programmer you can continue to use the old version as there has been no new functionality added and the bug only occurs with certain low cost USB-serial adapters.
GeoffEdited by Geoffg 2014-05-03
plasma
Posted: 10:44am 02 May 2014
today i had the first brick , time for an update !
Thx Geoff
