Local Time 11:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uMite strangeness
viscomjim
Posted: 01:14pm 28 Apr 2014
I cannont for the life of me figure this one out...
Have a 4x4 keyboard on 44 pin uMite and here is code...
Option autorun on
KeyPad keycode, kp_int, 21, 22, 23, 24, 25, 26, 27, 32
do
keycode = 99
print "first = " keycode
do:loop until keycode <> 99
print "second = " keycode
loop
kp_int:
IReturn
when run this is what happens...
first = 99
second = -1
over and over.
the second do loop falls through even as keycode prints that its 99, without any keys being pressed and somehow makes keycode = -1.
I tested the keypad using this program and every key works just fine...
Option autorun on
do:loop
kp_int:
print "keycode = " keycode
IReturn
Please show me the errors of my ways. I am loosing what little hair I have left.
Thanks!!!!
BobD
Posted: 01:33pm 28 Apr 2014
The use of keycode may clear the value in it. Try assigning the value of keycode to a variable and test the variable. The "cleared" value in keycode may be -1. That is no key pressed then keycode=-1.
We corrected Geoff a couple of days back. The word is "losing" your hair not "loosing" and I don't have much left either.
Edited by BobD 2014-04-29
Posted: 03:50pm 28 Apr 2014
Bob is close.
The value of the variable 'keycode' cannot be trusted to remain at the last entered key code.
Not mentioned in the manual, but it looks like -1 is used to indicate 'no key pressed'
The following gets around that problem:
I have used pins suitable for the 28 pin mucroMite.
KeyPad keycode, kp_int, 2, 3, 4, 5, 6, 7, 9, 10
do
mykeycode = 99
print "first = " mykeycode
do:loop until mykeycode <> 99
print "second = " mykeycode
loop
kp_int:
mykeycode = keycode
IReturn
I stopped having to worry about losing any more hair a long time ago...
Posted: 07:00pm 28 Apr 2014
This is my fault, for some reason I used the variable to record if no key press was detected, hence the -1 value. My only excuse is that I must have had a "bad hair day" (I still have a little left).
Jim's suggestion is an excellent solution. Because it is a minor bug with a good workaround I will leave the fix for the next release.
Posted: 07:37pm 28 Apr 2014
an argument could be put that if this behaviour was documented, then it would not be a bug at all. certainly, it is a perfectly acceptable way for the keypad functionality to work - my suggestion is to simply add this behaviour to the specification in the manual.
rob :-)
Posted: 08:59pm 28 Apr 2014
I agree with rob!
I would call it a feature!! Just needsto be documented.
You could then use it similarly to the inkey$.
Very useful for hold and repeat operations.
paceman
Posted: 09:53pm 28 Apr 2014
Viscomjim might also have been mis-directed by a couple of posts in this thread Umite keypad and interrupts posted 18th March 10:12 & 10:59pm.
  paceman said
  robert.rozee said   ... and, of course, one can process a keystroke (in polled mode) then set KeyCode to an unused value (such as -1). you then just need to wait for KeyCode to change value again to indicate the next keypress - i've not tried this, but it looks fairly obvious that it should work ok.
rob :-)
It works fine that way Rob. I'm doing that on UV lamp exposure controller now I'm working on now - code below. I just set it to 99 and loop till "keypress" returns as other than 99. I also got it to assign the 99 to another variable and convert it to a string but that's unnecessary - I just haven't changed it from some playing I was doing.[/Quote]
I had previously tried Rob's "-1" suggestion but couldn't get it to work either so changed it to the "99" technique quoted above which did work. I wasn't at all sure my code was OK but guess if I'd mentioned it then the fix would already now be in the current MicroMite firmware. Guess I should have qualified my "It works fine that way Rob" statement but in the context of that thread, I meant the technique of polling the variable as Rob mentioned, not the "-1" being OK.
Anyway it's sorted now and I agree with Rob and TZ that a mod to the Manual is the way to go - maybe include TassyJim's example.
As an aside to this I'll start a new topic with the code I finalised a month or so ago which uses a very similar treatment for keypad input and LCD display, just to document it properly.
Greg
