Local Time 11:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit update 3.4.9
Posted: 08:41pm 27 Apr 2014
New version 3.4.9 (28th April 2014)
I discovered that MMedit didn't like Silicon Labs CP2102 USB-serial adapters, or at least the version of the driver I was using.
This wasn't a problem until the MicroMite came along.
It took a couple of months, but I finally found the problem and, after a small change to MMedit, I am (reasonably) confident that the bug has been squashed.
There might be other adapters that have been fixed with this change but I don't know of any.
I have also changed the default action if you forget to save changes. The program now saves with the current name instead of asking for a name to save to each time. You still have the option of canceling and doing a 'SaveAs...'
The syntax help for the MicroMite has been updated.
The update can be downloaded for the usual location.
http://www.c-com.com.au/MMedit.htm
Posted: 09:36pm 27 Apr 2014
Have a beer on me.
paceman
Posted: 10:52pm 27 Apr 2014
  TassyJim said   New version 3.4.9
Yes I think that's a good change Jim, I often find myself thinking "err.. which file" etc.
Have a amber on me too.
Greg
