Local Time 11:20 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite IR (keyes remote)
Posted: 07:16am 24 Apr 2014
I tried using this remote on a micromite but it does not work.
I suspect that it has a different encoding that is not supported.
I had hopes that it would use the Sony encoding as i have several of these in stock.
Or, it can be that i did something wrong in a connection.
Did any of you guys tried a similar remote and got it to work?
plasma
Posted: 07:52am 24 Apr 2014
ive testet several remotes , only sony ones works , but why not build your own .
