Local Time 11:12 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : colour micromite
Posted: 09:37pm 12 Apr 2014
for your amusement, a little micromite demo i put together this afternoon that uses VT100 commands to set colour, X,Y position, and some (limited) character attributes:
clrscr
Print at$(21,3) colour$(4) "Colour MicroMite Demonstration"
For B=30 To 37
For C=40 To 47
Print at$((B-25)*4, C-35) colour$(1, B, C) "abcd"
Next C: Next B
Print at$(1, 20) colour$() "press enter to exit ";
Line Input a$
End
Function at$(x,y)
at$=Chr$(27)+"["+Str$(Y)+";"+Str$(X)+"H"
End Function
Function colour$(A, B, C)
Local temp$
temp$=Chr$(27)+"["+Str$(A)+"m"
If B<>0 Then temp$=temp$+Chr$(27)+"["+Str$(B)+"m"
If C<>0 Then temp$=temp$+Chr$(27)+"["+Str$(C)+"m"
colour$=temp$
End Function
Sub clrscr
Print Chr$(27)+"[2J"
End Sub
for the colour$ function the values to use can be found at the end of this page:
http://www.termsys.demon.co.uk/vtansi.htm
the 'blink' attribute doesn't seem to work for me with teraterm. note that if the program exits without a colour$(0) or colour$() then the micromite editor seems to miss resetting the colour attribute for the 2nd to last line of the screen.
enjoy,
rob :-)
Posted: 09:19am 13 Apr 2014
WOW - I really like that!
Could open up some very interesting possibilities with Geoff's VT Terminal Module that he said he might possibly design one day!
Posted: 09:30am 13 Apr 2014
rob,
On my 44-pin MicroMite module, if you press the reset button during the process of drawing the 'matrix', then TeraTerm's window keeps the background colour equal to that which was drawn at the time of reset!
Also the 'Colour MicroMite Demonstration' heading text is likewise in the colour too equal to the foreground colour that was being drawn.
The MicroMite has more colours than the MaxiMite
