Local Time 10:52 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quick RUN question....
Posted: 02:08pm 22 Mar 2014
As a nice quick way of resetting my system, I am thinking of just issuing RUN as a command in the listing. I have tested this at a very basic level, and seems to be working OK.
In my testing code, the SD card is checked to see if it is open for writing, and if it is, this is closed first before issuing the RUN command.
Is it safe to assume that the RUN command closes all ports, clears all buffers, strings, arrays, interrupts etc?
Perhaps I don't need to close an open port, if the RUN command will do all this for me?
Posted: 02:34pm 22 Mar 2014
Yes, RUN resets everything (ie, clears all variables, arrays, loops and resets I/O pins, communication ports, etc). So does NEW.Edited by Geoffg 2014-03-24
Posted: 02:48pm 22 Mar 2014
Excellent - just what I wanted. Thanks for the reply.
MOBI
Posted: 02:59pm 22 Mar 2014
  Graeme said  As a nice quick way of resetting my system, I am thinking of just issuing RUN as a command in the listing. I have tested this at a very basic level, and seems to be working OK.
I tried a few days ago to use "run" as a command in a programme to effect a programme reset and keep getting:
Error: Invalid in a program
How are you doing yours?
Reading between the lines, I gather you are using the MM hence the SD card reference. I have been trying to get it working on the uM.
Edited by MOBI 2014-03-24
David M.
Posted: 04:20pm 22 Mar 2014
RUN inside a program does not work on the Micromite. But you can get the same effect with OPTION WATCHDOG 1 which will immediately trigger the watchdog timer and (assuming AUTORUN is on) will restart the program.
MOBI
Posted: 04:53pm 22 Mar 2014
@ Geoff,
Thanks Geoff, I had forgotten about watchdog. I'll go down that track. Perhaps a side note in the RUN command of the manual could steer the unwary in the right direction.
Would it be too difficult to include RUN as a programme command? It would IMO make things easier?
David M.
Posted: 05:11pm 22 Mar 2014
  MOBI said  Would it be too difficult to include RUN as a programme command? It would IMO make things easier?
It would be very easy, in fact it would just consist of removing the code that checks for RUN in a running program. But I put that in because it would be illogical to run the same program within itself.
This is a balancing act in logic. In another thread on the BS the subject is the logicality of allowing a variable name to be the same as a function name. One of the things that I try to do is not put artificial barriers in the way of the programmer, even if it is illogical. So on that basis I should remove the restriction on RUN inside a program.
Thanks for triggering the thought experiment - I will make the change in the next version.
Posted: 05:35pm 22 Mar 2014
Hi folks.
@ MOBI - YES, I am using the full-size colour Maximite for this RUN command.
Basically, I am using it as a RESET kind of command, because it will save me having to close ports, empty strings and variables, and also allows the code to start again right from the beginning, so it won't hold onto any deeply hidden bug in a string or something!
Probably not the most expert, professional or otherwise standard of coding practice, but hey - if it works....
BTW - I have not dropped the MicroMite, I just need to finish this Maximite code so that then I CAN concentrate fully on the new beast!
MOBI
Posted: 05:57pm 22 Mar 2014
  Quote  @ MOBI - YES, I am using the full-size colour Maximite for this RUN command.
As I recall, Microsoft basic and apple basic etc, all allowed the RUN command within the programme. Although it would be nice to have on the uM, if AUTORUN mode is on, then inserting a WATCHDOG 1 command is just as good:
e.g.
if Keycode = 10 then: watchdog 1: endif
will work nicely as an escape key. (10 is the * key on the hex pad)
The programme will restart with the watchdog off (reset).
  Graeme said  BTW - I have not dropped the MicroMite
Nose wet. I'm patient or is that Impatient? What a difference an apostrophe makes.
David M.
