Local Time 04:53 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Engineering format for MMBasic
Posted: 05:30pm 15 Mar 2014
Sometimes it is preferable to format numbers in either exponential or engineering formats
This function does either.
Engineering notation is exponential notation with the exponent alwas a multiple of 3
The function was written for the MicroMite and works but does not display a positive sign for the exponent on other versions of MMbasic.
The three inputs are:
number to format
number of decimal places displayed
engineering notation (anything other than zero = engineering), zero or omitted = standard exponential
' MicroMite
'format number in Engineering notation
' TassyJim 16 March 2014
main:
input "Number to format";n
print str$(n)+" "+StrE$(n, 3)+" "+StrE$(n, 3, 1)
goto main
function strE$(mx,p, eng)
' mx = number to format
' p = number of decinal places
' if eng is not zero, use engineering notation
local px, sn$, x
sn$=" "
x=mx
If x < 0 then
sn$ = "-"
x = x * -1
EndIf
if x<>0 then ' zero is a special case
px=int(Log(x)/ log(10))
if eng <> 0 then ' engineering notation - multiples of 3
px = int(px/3)*3
endif
x=x*(10^-px)
strE$ = sn$ + Str$(x, 0, p) + "e" + Str$(px,-1)
else
endif
end function
The output:
Number to format? 12345.678
12345.7 1.235e+4 12.346e+3
