Local Time 04:52 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uM I2C read command
BobD
Posted: 11:48am 15 Mar 2014
In the Maximite, when using I2C command I2Crcv there is the capability of combining a write and a read into one I2C command.
From Maximite Language Reference V4.4b with the relevant parts in blue.
[quote]Syntax
I2CRCV addr, bus_hold,rcvlen, rcvbuf [,sendlen,senddata [,sendata ....
Examples
I2CRCV &h6f, 1, 4, anarray(2), 3, &h12, &h34, &h89
I2CRCV &h6f, 1, 3, anarray(0), 4, anotherarray(0) [/quote]
In the Maximite, I find it useful to be able to set a buffer pointer in a chip and then do an immediate read in one line of code.
Example: Read register 14 in a DS3231 with the implied write in blue.
[quote]I2Crcv &h68,0,1,Reg14_data,1,14 [/quote]
The above can be used instead of
[code]I2Csend &h68,0,1,14
I2Crcv &h68,0,1,Reg14_data [/code]
Does this feature exist in MicroMite Basic? It is not mentioned in the Manual and I am not yet in a position to test.
Posted: 01:04pm 15 Mar 2014
No, I had to remove it when I was slimming down the I2C routines to get them into the Micromite. So, as you pointed out, you will need to use two separate commands.
