Local Time 04:51 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CUBLOCK industrial grade BASIC controller
JohnL
Posted: 04:25pm 12 Mar 2014
http://www.comfiletech.com/coremodule.aspx
Comfile CUBLOCK modules programmed in BASIC.
Professional embedded microcontroller modules. .
Industrial grade quality.
Reasonably priced from $29.
South Korean company has been developing industrial automation products since 1996.
Simple and Easy PC based IDE/Compiler for both Basic and Ladder logic.
Very easy and comprehensive traditional or structured compiled BASIC with lots of functions and variations of functions. Different data types including bit, byte, integer, word , float, bit manipulations including shift, full math and trig. , very comprehensive string handling, arrays. Keyboard input function with de-bounce parameter, PWM, frequency, pulse, count, case, interrupts, Serial, I2C, SPI etc.etc.
Comprehensive product/programming manual with examples plus additional tutorials for Newbies.
Supports very easy Ladder logic programming as multitasking with Basic.
Libraries and BASIC functions for LCD displays, Modbus, etc.
Modules come with up to 91 I/O port pins, RTclock etc.
Some modules come with additional battery backed Heap Ram that is supported by Basic commands.
Reasonably priced development/prototype base boards.
Larger modules have non standard 2mm pin spacing.
Manuals, IDE etc. in Download >> Cublock section.
Upgrade path to more advanced industrial grade products.
Link to very nice illustrated tutorial for newbies.
http://cubloc.com/download/cubloc/cubloc_startbook.pdf
Posted: 05:38pm 12 Mar 2014
They do a nice range of products. I really like their manual/tutorial for beginners.
So have you used these modules yourself? If so what is your overall impression of them?
