Local Time 10:42 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Beta 9
atmega8
Posted: 08:57pm 06 Mar 2014
first Test
This code works fine,
the issue with printing negative values is fixed.
Thanks Geoff!
RotaryValue = 0
RotaryA = 2
RotaryB = 3
SetPin RotaryA, INTH, RotaryInterrupt
SetPin RotaryB, DIN
Print RotaryValue,
'Add usefull stuff here
Loop
Sub RotaryInterrupt
If Pin(RotaryB) = 1 Then
RotaryValue = RotaryValue - 1
Else
RotaryValue = RotaryValue + 1
EndIf
End Sub
Frank N. Furter
Posted: 09:22pm 06 Mar 2014
I tested Beta 9 on 44 pin device - IIC seems to work ok with my ISL29023 lightsensor.
BUT... I can't search within the editor! (I changed the lines with "option lines 36" to 36)
When I search anything with F3 the RETURN Key will not recogniced. When I press F3 again or ESC I get the message "NOT FOUND"
EDIT:
There's the same problem on 28 pin device (without changing the lines)...
FrankEdited by Frank N. Furter 2014-03-08
jwettroth
Posted: 09:49pm 06 Mar 2014
Beta 9 runs my thermometer code out of the box- I like the "+"'s,
I found the issue with IPE- I misdefined part- all at my end.
I will run some negative number tests and do some I2C tests with a couple of odd parts that I have.
Looks Good,
John Wettroth
Posted: 10:08pm 06 Mar 2014
  Frank N. Furter said  When I search anything with F3 the RETURN Key will not recogniced.
Ah, sorry for that. I added that bug when I changed line input to terminate on a CR. I should not fiddle with working code !!
I have rushed out beta 10 which fixes this issue so please skip beta 9 and go straight to 10.
Frank N. Furter
Posted: 11:27pm 06 Mar 2014
Hi Geoff,
I thougt there is a relationship between your "line input" change and this bug.
Thank you very much for beta 10 - I will test it...
Frank
