Local Time 10:42 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New chips from Microchip soon
kiiid
Posted: 11:18am 05 Mar 2014
PIC32MX170 and PIC32MX270 - 256k flash and 64k RAM, the first one without USB.
http://rittle.org
Lou
Posted: 11:42am 05 Mar 2014
.... hope so, it could be uMite on steroids.
Lou
kiiid
Posted: 11:49am 05 Mar 2014
...Edited by kiiid 2014-03-06
http://rittle.org
Zonker
Posted: 05:55pm 05 Mar 2014
I would hope to see improvements on the TFT version.. Maybe better resolution and color... Maybe more complex UI based objects built inside... Could be Awesome...!! Just think want we have already been given.. Wow quite a ride so far..
plasma
Posted: 07:44am 06 Mar 2014
cant find any link or google result .
Posted: 08:00am 06 Mar 2014
Already in the 1xx/2xx data sheet - found from google using
"PIC32MX170"
plasma
Posted: 08:15am 06 Mar 2014
nothing ! really !!
Posted: 08:23am 06 Mar 2014
here you go first and only! result from google:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&c d=1&cad=rja&uact=8&ved=0CCUQFjAA&url=http%3A%2F%2Fww1.microc hip.com%2Fdownloads%2Fen%2FDeviceDoc%2F60001168F.pdf&ei=1rwY U9PsMKXZigeT2YGgBQ&usg=AFQjCNF2rRsq_LcWqerw6wf8X4VtUjI10Q&si g2=WT3MT_Yxdx5k69awcIGLpQ&bvm=bv.62577051,d.aGc Edited by TZAdvantage 2014-03-07
Posted: 09:03am 06 Mar 2014
Bug in German version of google?
You could use .co.uk version or .com version to check.
plasma
Posted: 09:57am 06 Mar 2014
nothing ! also in co.uk !
i use a ipad .
it sounds mad , i make a upload from a screenie.
plasma
Posted: 09:58am 06 Mar 2014
elproducts
Posted: 10:51am 06 Mar 2014
Geoff won't have to count bits anymore on the Micromite.
www.elproducts.com
JTR0701
Posted: 11:07am 06 Mar 2014
These parts will be a very welcome addition. Thanks for the heads-up.
Posted: 11:31am 06 Mar 2014
Using the .co.uk you get a response in English not German so it's ignored the attempt to use the .co.uk!
I get:
[PDF]
PIC32MX1XX/2XX - Microchip
ww1.microchip.com/downloads/en/DeviceDoc/60001168F.pdf
FIGURE 4-5: MEMORY MAP ON RESET FOR PIC32MX170/270 DEVICES (64 KB RAM, 256 KB FLASH). Virtual. Memory Map(1). Physical. Memory Map(1).
Posted: 12:20pm 06 Mar 2014
Sure the 170 & 270 are mentioned in the data sheet but I cannot find anywhere on the web any other mention of them.
Trying both the Microchip website and their online store site yields nothing. I am trying to get samples or buy them but nothing
Has anyone got any clue as to when (and where!) these are available?
Thanks . . . .
Posted: 12:42pm 06 Mar 2014
Well, the PIC32MZ was similarly visible and now exists (albeit broken).
So, just be a lil patient?
vasi
Posted: 01:02pm 06 Mar 2014
Thanks . . . .
It was also true for PIC18F46K22. I got tired waiting for it. Now is on my breadboard, but I should have waited much more longer instead of participating against my will in a kind of beta testing on my money. A beta testing which should be made in-house and a product which does not work should be considered as defective and retired from the market. With apologies!
Edited by vasi 2014-03-07
Elvish name: Mablung Miriel
Beyound Arduino Lang
kiiid
Posted: 01:26pm 06 Mar 2014
Late Q2/14
http://rittle.org
Posted: 03:29pm 06 Mar 2014
  kiiid said
Late Q2/14
Please - where have you seen or heard this from ? Is it a reliable source of info?
Thanks . . .
kiiid
Posted: 04:06pm 06 Mar 2014
Yes, it is from a reliable source.
http://rittle.org
