Local Time 04:35 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RTC module
viscomjim
Posted: 09:09am 02 Mar 2014
Does anyone know if the real time clock interface mmbasic command for PCF8563 in uMite is compatible with the DS1307 or the DS3231 ChronoDot modules sold by adafruit?
Thanks!!!
BobD
Posted: 09:29am 02 Mar 2014
  viscomjim said   Does anyone know if the real time clock interface mmbasic command for PCF8563 in uMite is compatible with the DS1307 or the DS3231 ChronoDot modules sold by adafruit?
Thanks!!!
It is not compatible. Check the datasheets of both devices.
Posted: 10:12am 02 Mar 2014
It is not the same but all the mentioned RTC modules ate I2C and easy to talk to from MM Basic.
Each RTC has its own advantages and disadvantages.
If you are intending to run from 3.3V, don't use the DS1307.
Posted: 12:08pm 02 Mar 2014
  TassyJim said  RTC modules ate I2C and easy to talk to from MM Basic.
How do you eat an I2C?
Posted: 12:42pm 02 Mar 2014
With chips.
Lou
Posted: 12:47pm 02 Mar 2014
Good one TassyJim. I was wondering myself, now I know.
Lou
Posted: 02:23pm 02 Mar 2014
With chips.
Excellent come-back, and a double-pun!
Well done!
jpconil
Posted: 10:34pm 02 Mar 2014
Hello,
Here is the code I am using with a DS1307 connected to a Duinomite-Mini running MMBasic V4.4B :
'Ce programme de test marche avec un DS1307
'On lit l'heure, la date etc puis on l'affiche
Dim Table(8)
I2CEN 100,100
I2CRCV &h68, 0, 7, Table(1), 1, &h00 'lit les secondes, minutes, etc
Secondes = ((Table(1) And &b01110000)/16)*10 + (Table(1) And &b1111)
Minutes = ((Table(2) And &b01110000)/16)*10 + (Table(2) And &b1111)
Heures = ((Table(3) And &b01110000)/16)*10 + (Table(3) And &b1111)
Cls
Print Heures; " :"; Minutes ; " :"; Secondes
Pause 1000
Loop
I got a module with a Lithium battery for US$1.5 on ebay. But it has an error of several seconds by day. There is another product of Maxim vith a better accuracy and the same I2C adress.
Cordially
viscomjim
Posted: 11:41am 03 Mar 2014
Hi jpconil,
That code looks easier than what I thought it would be. Do you have code to set the time for the ds1307? The PCF8563 module seems to be difficult to get here in the states, unless I get it from overseas.
Thanks for you for your time.
