Local Time 10:32 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Peek and Poke
plasma
Posted: 11:07pm 18 Feb 2014
hi,
What can i do with these Commands in the Micromite ?
any hints ?
thx
vasi
Posted: 12:51am 19 Feb 2014
I guess those are useful especially when you lost some debates with Geoff regarding firmware implementation...
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 10:39am 19 Feb 2014
I made use of them to create a method of having short strings to save space.
Not needed now since Geoff added the option to specify length for arrays.
http://www.thebackshed.com/forum/forum_posts.asp?TID=5236&KW =short+string
Poke can be dangerous to use!
atmega8
Posted: 10:46am 19 Feb 2014
  vasi said   I guess those are useful especially when you lost some debates with Geoff regarding firmware implementation...
Not a very usefull comment.
vasi
Posted: 10:55am 19 Feb 2014
Definitely, a bad joke, apologies! Doesn't matter what I thought about peek and poke in a microcontroller world...
Geoff could chose to make some special zones where those can be useful or drop them definitively. I can't wait for him to finish with the improvements also for the Maximites to start asking him for bytecode compilation where we will get a lot more memory space and execution speed. Maybe there peek and poke will be really useful?
Posted: 04:34pm 19 Feb 2014
I only put in peek/poke because people kept asking for it - probably based on their experience with the TRS-80s of yesterday. Not because it was particularly useful.
Peek/poke might come in handy if you wanted to change the PIC32's registers and implement something that BASIC does not - but that would be rare because almost everything that the chip can do is handled by MMBasic anyway.
Posted: 06:54pm 19 Feb 2014
I have NEVER used any peek or poke command in MMBasic. Perhaps it is better to drop them from uM especially, along with you repeating the above to hammer home the reasons.....
I suppose it depends on if you would save much memory by removing them or not.
