Local Time 05:46 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Beta 6
     Page 1 of 9
Posted: 05:43pm 12 Feb 2014
Just a quick message to tell any Micromite Beta testers to check their inbox for the latest version.
The big change is that it now has built in commands to handle a number of common peripheral devices. These are:
- Infra-Red remote controls
- The DS18B20 temperature sensor
- Servos
- 1, 2 and 4 line LCD display modules
- The PCF8563 battery backed clock
- 4x3 and 4x4 numeric keypads
Posted: 05:59pm 12 Feb 2014
Geoff,
You have outdone yourself....
I have wanted to build an IR repeater for a specific task for some time... The other devices supported are a great addition as well.
Very well done and greatly appreciated..
If you come to Melbourne i will buy you a `proper' beer.
jman
Posted: 06:05pm 12 Feb 2014
Fantastic additions
IR just what the doctor ordered
Well Done Geoff
Next time you in Christchurch I will buy you a proper "NZ Beer"
not a Melbourne cheapie :)
"Hi Mick"
Jman
Posted: 06:27pm 12 Feb 2014
...and Geoff waves his magic wand once again...
Great stuff, Geoff - especially like the built-in commands for LCD's and matrix keypads. The RTC commands will be very handy, if you need to put an RTC on your MicroMite...
Posted: 06:44pm 12 Feb 2014
Is there no stopping you Geoff? (I hope not!!)
Been up all night here in flooded UK finalising TQFP Eval PCB/Module prepping it for fab house. I was just about to go to bed (now 04:30) when I saw your email. Now tempted to stay up for another hour or two upgrading all my MicroMites (got 11 built so far ).
Brilliant news regarding LCD driving - will be able to test various including 1x8, 1x16, 2x16, 2x20, 2x40, 3x16, 4x20, 2x40 but not tonight
Now can you please hurry along with Beta 7 and include voice & fingerprint recognition, body scanning, and teleporting. (we all expect this by next week assuming you're not too busy on other things . . . .)
OA47
Posted: 07:03pm 12 Feb 2014
Geoff, is there a chance we will see these wonderful new additions for the Maximite?
JohnL
Posted: 07:04pm 12 Feb 2014
WOW!!!
What can I say, WE OWE YOU HEAPS Geoff.
Well done.
Just testing DS18s20 I think my is S and it is working like a charm with one single command.
psergiu
Posted: 08:00pm 12 Feb 2014
Wonderful !
Built-in support for Olimex mod-rtc and most of the stuff i wanted connected to a *mite
Can't wait for the maximite version of this firmware.
Thanks a lot !
MOBI
Posted: 08:10pm 12 Feb 2014
Accolades from this quarter also.
Just cosmetic at this stage, page 7 44pin chip pin 41 should be MISO not MOSO.
David M.
Posted: 08:13pm 12 Feb 2014
  Graeme Meager said   Geoff, is there a chance we will see these wonderful new additions for the Maximite?
According to Geoff in the other FORTY PAGE thread, he wrote the following on page 40:
[quote]
After I have Finished with the Micromite I intend to retrofit a lot of its features into the Maximite/Duinomite/ColoutMM/etc.
It won't be immediately but that is on the roadmap.
[/quote]
So YES, with a bit of a waiting period I expect.
atmega8
Posted: 09:03pm 12 Feb 2014
XMODEM !
When trying to downloda via Xmodem, the transfer stucks.
After stopping , the content of the downloadfile was wiped out.
Tried it several times, same effect.
Used Treraterm with 38400.
vasi
Posted: 09:05pm 12 Feb 2014
Now you can't ignore Micromite. Is fantastic for a farmer and a RE enthusiast.
to Geoff.
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 09:15pm 12 Feb 2014
  atmega8 said   XMODEM !
That cannot be right, most of my testing was done using XModem to transfer files.
I will recheck but I am baffled.
MOBI
Posted: 09:19pm 12 Feb 2014
Sorry Geoff,
Mine has done exactly the same thing. I didn't have a backup of the text file and now I'm afraid it has gone to the big bit bucket in the sky.
The file still exists but blank!!! Bugger!!!
I tried again - made a backup copy of another file and this time it worked ok. Baffled also.Edited by MOBI 2014-02-14
David M.
JohnL
Posted: 10:11pm 12 Feb 2014
Transferred few 3-4KB files xmodem and Tera Term both ways at 38400BPS, absolutely NO problems.
Maybe there are issues on your PC side?
Edited by JohnL 2014-02-14
Posted: 10:29pm 12 Feb 2014
The SERVO command is particular interesting as it will make controlling robotic parts easy.
Is there a reason why not all five internal OC peripherals can be used?
The pins are if i read correctly remappable, would it be possible to to add PWM capability to some digital pins?
A typical robot arm has a four/five servos and controlling it from a single mcu would be fantastic. (Like this: uArm)
Imagine if they used a uMite, then everyone could hack the software as BASIC is so much easier to use.
Having a lot of PWM capable pins is one of the reasons why the arduino is used often.
It would please me to no end if i can prevent using the arduino for that.
Edited by TZAdvantage 2014-02-14
MOBI
Posted: 10:46pm 12 Feb 2014
  JohnL said  Transferred few 3-4KB files xmodem and Tera Term both ways at 38400BPS, absolutely NO problems.
I have done the same also since with no problems. I'll insert another chip and see if it is a "first time" effect - hard to believe but worth a try.
As for issues with the PC, absolutely nothing has changed other than to load run the latest beta.Edited by MOBI 2014-02-14
David M.
Posted: 10:52pm 12 Feb 2014
I also have no problems using XMODEM at 38k4.
Used the same circuit on the breadboard, just programmed the new beta version.
Posted: 11:22pm 12 Feb 2014
Is the problem copying PC ---> Micromite or PC <---- Micromite?
JohnL
Posted: 11:40pm 12 Feb 2014
  Quote  XMODEM !
If you try to transfer file from PC-->Micromite using xmodem and Tera Term.
In Tera Term you must use File-->Transfer-->XMODEM-->Send.
If you use ....XMODEM-->Receive you will wipe out the file on PC, and yes it will be stuck because it is trying to receive file from Micromite and save it in new blank file, while Micromite is wating to receive file as well.
You may have confused Receive and Send.
Micromite Receives and Tera Term needs to send.
Micromite Sends and Tera Term needs to receive.
Geoff, I recon that was the problem?Edited by JohnL 2014-02-14
     Page 1 of 9
