Local Time 04:24 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite date bug?
Juri74
Posted: 07:59am 04 Feb 2014
hello..
try
DATE$="30-02-2014"
Print DATE$
regards
juri
atmega8
Posted: 08:48am 04 Feb 2014
works as expected:
> DATE$="30-02-2014"
> print date$
30-02-2014
BobD
Posted: 08:54am 04 Feb 2014
So you are saying you can set the date wrong. Try setting to 23:59 on 28-02-2014 and see if it transitions to 01-03-2014 correctly.
atmega8
Posted: 09:56am 04 Feb 2014
Transition to 01-03-2014 works also correct
donmck
Posted: 06:22pm 04 Feb 2014
Really a matter of how far you go with error checking code, when it is obviously a user input error. Like month 13. Do you check for this?
As long as you can input an actual date, and have it rollover correctly, then all is well.
Don...
https://www.dontronics.com
Posted: 01:34pm 05 Feb 2014
This is what I use for my RTC setting:
[code]
BF=0
if len(lin$)<>8 then BF=1
if mid$(lin$,3,1)<>":" or mid$(lin$,6,1)<>":" then BF=1
if val(mid$(lin$,1,2))<0 or val(mid$(lin$,1,2))>24 then BF=1
if VAL(mid$(lin$,4,2))<0 or val(mid$(lin$,4,2))>59 then BF=1
if val(mid$(lin$,7,2))<0 or val(mid$(lin$,7,2))>59 then BF=1
if BF=1 then
print @(35,150) + clr$(Red) "Unacceptable format."
pause 2500:goto start
endif
Time$=lin$:GoTo Start
[/code]
And for setting and checking the date:
[code]
BF=0
if mid$(lin$,3,1)<>"-" or mid$(lin$,6,1)<>"-" then BF=1
if val(mid$(lin$,1,2))<1 or val(mid$(lin$,1,2))>31 then BF=1
if VAL(mid$(lin$,4,2))<1 or val(mid$(lin$,4,2))>12 then BF=1
if val(mid$(lin$,7,2))<1 or val(mid$(lin$,7,2))>99 then BF=1
if BF=1 then
endif
date$=lin$
gosub SetLog
GoTo Start
[/code]
lin$ is the user-entered date or time string.
This is basic, and still allows you to enter something along the lines of 30-02-14 for the date, which you have already mentioned, is an illegal date, however some checking is better then none.
I expect that the checking could be expanded with the help of a string array, so that if "02" was specified as the month, then the day cannot be greater then "28". I don't imagine that would be THAT hard to do.
As Don says - how far do you really go with this kind of error checking? (rhetorical!)
