Local Time 10:24 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TeraTerm text transfer
MOBI
Posted: 09:17pm 02 Feb 2014
I would like to transfer programmes to and from Tera Term and the parent PC. I am using TT with uMite.
I can copy and paste from Tera Term to a text file on the PC and I can copy from the PC text file and it shows up ok on the Tera Term clipboard but when I paste, I get a rubbishy version of what is on the clip board. TT help doesn't help much.
Can I in fact do this or what am I doing wrong?
edit update:
If I put the uMite into "edit" mode and set the comm port transmit delay to say 80, I get a clean copy which will run ok. But I could just about type faster than the transfer rate. Is the slowness due to transferring the data to the uMite flash?
Edited by MOBI 2014-02-04
David M.
Posted: 09:34pm 02 Feb 2014
Start by trying with a small selection of text.
Paste uses Alt_V instead of the usual Ctrl_V
The right mouse button also pastes immediately unless you have disabled that in Setup/Additional settings/Copy and Paste.
I use MMedit so I have little experience with pasting full programs using TT.
Edit:
under the above settings, you can set the LINE delay which should help.
Edited by TassyJim 2014-02-04
Posted: 11:20pm 02 Feb 2014
Would using xmodem not be better (and easier) to transfer programs?
MOBI
Posted: 12:12am 03 Feb 2014
  Quote  Would using xmodem not be better (and easier) to transfer programs
Quite likely. The last time I used Christensen protocol was with the Micro Professor and an 8" floppy based cpM machine(a lifetime ago).
Any pointers on, say, writing a programme to a text file and then transferring it to Tera Term?
David M.
Posted: 12:25am 03 Feb 2014
The uMite has XMODEM command to send and receive programs.
Also an AUTOSAVE command to stream text to the uMite.
Would those not work?
If i misunderstand the goal maybe an example can clear that up.
MOBI
Posted: 02:01am 03 Feb 2014
I can make autosave work using cut and paste from a text file but xmodem is causing me a little grief. It is too late at night I think and I'm too tired - tomorrow I try again.
David M.
MOBI
Posted: 11:44am 03 Feb 2014
Further to above, I have been lucky to get anything working properly. I had a wobbly connection in the cheap Chinese serial cable. All is doing what it is supposed to and files transfer both ways happily.
David M.
