Local Time 04:12 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIC32 is hot.
Posted: 10:39pm 10 Jan 2014
Hi all.
How hot is too hot?
When idle, the PIC32 is about 27'c
When I feed it processor intensive tasks at 100% duty-cycle, the heat rises to about 50'c at the plastic case of the IC.
That's pretty hot, and is hot to the touch.(the chip is)
Heat is a killer of electronics, so is that still normal?
Perhaps one of those little stick-on heatsinks would be a good idea...Edited by Grogster 2014-01-12
Posted: 10:51pm 10 Jan 2014
Perhaps I am over-reacting?
When I run something like COLOUR-1.BAS for several minutes, I discover that the IC heat is about the same at roughly 40'c
This time I used a laser thermometer, last time I used my finger.
I might be wrong on this one - fingers have thermal lag...
EDIT: Bloody Vodka is screwing with my ability to be logical tonight.
You can probably ignore this thread....
Posted: 02:00am 11 Jan 2014
There is no difference between the processor waiting for input and actually doing something. It keeps running at the same speed and drawing the same power and therefore generating the same amount of heat.
Normally the PIC32 runs a little warm but definitely not burning hot. You can make it run a bit hotter if you are sinking or sourcing a lot of current through the I/O pins.
Watch out for that Vodka...
Posted: 01:26pm 11 Jan 2014
Beer is good, Vodka is bad....
