Local Time 10:16 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Changing MODEs kills SETTICK?
Posted: 04:43pm 09 Jan 2014
Hi all.
From what I can tell, if you set a mode, say, MODE 4, then set some timer interrupts with the SETTICK command, if you change mode, all the tick timers are cancelled.
Is this normal?
I cannot find anything under the MODE command in the manual(page 27 of 4.4B manual) that indicates that this will happen.
If it is normal, that's fine - I would just like to know if it is. If that is indeed normal, I will just have to move my setick timers to a gosub of their own, and call them as soon as I change modes.
No big deal, just wondering is all....
Posted: 05:36pm 09 Jan 2014
I suspect that something must be wrong with your program.
I ran the following test and the tick interrupt kept ticking.
Mode 3
SetTick 1000, DO_TICK
If Inkey$ <> "" Then Mode 4 : Print "Mode changed"
Loop
DO_TICK:
Print "tick"
IReturn
Posted: 09:40pm 09 Jan 2014
Yes, I ran this and came to the same conclusion.
I did re-write your SETTICK to SETTICK 1000, DO_TICK, 1 so that I was specifying one of the four tick timers, as I thought that might be linked to that, but it worked fine.
I will have an in-depth look at my code for a bug - if the SETTICK is supposed to keep working regardless of the mode, then it must be something in my code, as you say.
I will post back when I find the problem.
Posted: 10:09pm 09 Jan 2014
How to bollocks up some code 101:
Call an interrupt, then don't return it...
