Local Time 04:04 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pong
elproducts
Posted: 02:48am 18 Dec 2013
Anybody know of a simple pong game for maximite?
www.elproducts.com
elproducts
Posted: 03:58am 20 Dec 2013
After 106 views and no responses I'll take that as a no.
I guess I'll try to create one.
I've found some old examples written in QBASIC but they are all complex variations.
Any many didn't run on the Maximite without tons of errors or crashing the program.
I'll try to make a simple version using sprites (which I've been wanting to learn more about anyway).
Plan is to document each step as a training module for teaching beginners how to use the Maximite.
www.elproducts.com
vegipete
Posted: 02:05pm 20 Dec 2013
I haven't noticed a pong game but perhaps my Break Out game can give you some inspiration. (The latest version is a few posts down.)
paceman
Posted: 06:31pm 20 Dec 2013
There's one on Geoff's website, but it's not for a Maximite.
MOBI
Posted: 08:39pm 20 Dec 2013
  Quote  There's one on Geoff's website, but it's not for a Maximite
The version of Pong on Geoff's web site is a PIC based hardware version unless there is another I have missed.
I wrote a Pong programme years ago for an OSI Superboard MC and it wasn't too difficult. I might still have the source code listing somewhere but don't hold your breath.
My video was memory mapped so most of the paddle and ball motion was achieved using copious quantities of PEEK and POKE commands.
Here's your chance to write one for the MM library???
David M.
elproducts
Posted: 04:39am 21 Dec 2013
  vegipete said   I haven't noticed a pong game but perhaps my Break Out game can give you some inspiration. (The latest version is a few posts down.)
Thanks vegipete,
That was extremely helpful.
I produced a bouncing ball as a Sprite that runs around bouncing off the edges of the screen using the collision command. This has worked well.
Then I added a sprite for the paddles and found the 16x16 limitation of the Sprite size makes for a very small paddle (I am running in mode 1).
I see you didn't use Sprites for your paddle at the bottom of your breakout game so that will take me some time to sort that out and how you determine collisions.
My thought was I'd have to combine two or three sprites to make a bigger paddle and then move them together and then I could still use the collision command.
I also learned you can't use the same Sprite twice as MMBasic reports it's already being used.
So right now it appears I have to create a separate sprite for the second paddle.
I'm going to look at Nick's code as well since he has some of the best game examples I've seen anybody produce.
www.elproducts.com
darthmite
Posted: 10:16am 22 Dec 2013
I have write a Breakout game for the MM v2.x and v4.x long time ago.
It must be in the MM Library.
If you just need a pong game , remove the wall from the code :)
Cheers.
vegipete
Posted: 05:02pm 22 Dec 2013
  elproducts said  I see you didn't use Sprites for your paddle at the bottom of your breakout game so that will take me some time to sort that out and how you determine collisions.
Yes, I went with custom characters in my own font to get past the 16x16 size limit. That does limit you to a single colour for the object but that isn't a huge draw-back. 'Collision detection' happens in the math of placing the ball on screen. I know the coordinates I'm drawing the ball and I know the coordinates of the paddle so it doesn't take much to calculate a hit or a miss. You can decide which is easier - shifting 2 or 3 sprites around together or shifting a single 'letter' and checking for collisions yourself.
  Quote  I also learned you can't use the same Sprite twice as MMBasic reports it's already being used.
There is a new command in the latest MMBasic versions that allows you to copy a sprite to an (empty) sprite space. This makes it easy to display the same sprite more than once on screen.
