Local Time 03:55 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Invisible Touch Area
Zonker
Posted: 06:51pm 17 Nov 2013
Good evening all..!
I was trying to create button touch areas on top of small BMP file images to make graphic looking buttons but I can't seem to get past the command...
touch size 100,100
touch create 0,100,100
do while touched(0)=0: loop
the create produces a syntax error... not sure why...
PDF says:
TOUCH CREATE r, x, y
Will create a touch sensitive area on the screen with no
corresponding visible image. 'r' is the reference number. 'x' and 'y'
are its position in pixels
Has anyone else tried this..?
Posted: 08:51pm 17 Nov 2013
What line creates the syntax error?
Zonker
Posted: 01:53am 18 Nov 2013
Hi Geoff..!
It's the create line "touch create 0,100,100" that trips the syntax error...
Not sure why.. I think I am typing it in right..
Posted: 04:51am 18 Nov 2013
Damn, it is a bug.
The workaround is to add two dummy parameters to the command.
For example:
TOUCH CREATE 1, 100, 100
will cause a syntax error, while
TOUCH CREATE 1, 100, 100, "", 0
will work correctly (the last two parameters are ignored).
I will fix it in the next release.
Zonker
Posted: 01:52pm 18 Nov 2013
Good evening fine Sir.
Thanks for the quick response.. Using the workaround is no problem..! Just glad there is a way to continue testing...
Update: Looks like the workaround makes it function correctly... (sweet!)
Still working on adding objects to the UI Lib...
Thanks much Geoff.!!Edited by Zonker 2013-11-20
