Local Time 03:54 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Olimex Duinomite and other stock in Aust.
donmck
Posted: 10:47am 13 Nov 2013
Olimex Duinomite and other stock in Australia.
My stock is now getting very low on the 30% OFF price on Duinomite boards. When stock is gone, you will have to purchase direct from Bulgaria at normal retail prices.
http://www.dontronics-shop.com/the-maximite-computer.html
I have also set a new price on the Olimex-DuinoMite-eMega-Ethernet board at 50% OFF.
Quick summary:
Runs DuinoMite Basic. Only had a 15 minute test. All 20 I/O lines working in digital mode. Tested to a Test-a-Mite tester. Has Ethernet, however there are no drivers for Ethernet at the moment.
No shared pins apart from SPI bus, as this is done on a 100 pin PIC32MX795L microcontroller. UEXT and SD-card share the same SPI but have separate chip select pins so there should be no problems.
May be better suited to C programmers. A great board at a great price.
http://www.dontronics-shop.com/olimex-duinomite-emega-ethern et.html
And all other Olimex products are now a minimum 30%+ off normal Olimex Prices.
http://www.dontronics-shop.com/olimex-ltd.html
All Olinuxino LINUX PC boards now 50% OFF
http://www.dontronics-shop.com/olinuxino.html
Don...Edited by donmck 2013-11-14
https://www.dontronics.com
