Local Time 03:47 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Caps-Lock to Upper-Case?
Nixie
Posted: 12:24am 30 Oct 2013
Greetings All!
I have a couple of questions.
Is there any way to check (using software ) to see if the Caps-Lock Key is On?
and;
Is there any way to "lock" it into Upper-Case...well, for the duration of the program?
Many thanks in advance, Nic.
VK3COW
Posted: 12:49am 30 Oct 2013
At this time the answer is no to both questions.
I have a new version of MMBasic (which will be out in a few days) and it operates the Caps Lock LED on the keyboard - but that does not help if you want to detect it in software.
If you wanted all input to be in upper case you could use the UCASE$() function on any input. That would give a similar result to forcing caps lock.
Nixie
Posted: 01:06am 30 Oct 2013
Geoff, many thanks for that.
I can use that as a "work around" .....
In fact, after more scratching and thinking, the UCASE$() function may be a much better option.
Yes! Great!
Nic
