Local Time 09:54 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help-Color Maxi+Freetronics relay driver
zcontrol
Posted: 10:23pm 29 Sep 2013
HI Folks,
I'm new to the maximite scene but have been playing in the retro computing scene for a while.
I am currently trying to use the color maximite to control a model railway both for input and output.
To help get things moving quickly, I invested in a Freetronics Arduino relay driver shield, plugged it into the maximite and have been trying to get it working to days with no luck.
The first problem I had was not realising I had to set the SCL / SDA jumpers on the maximite board.
Once I did that I could then send commands to the board via the I2CSend command and not recieve an error however, it does not appear that the board is actually doing anything. What I am expecting to see is a relay driver led come on when I send the corresponding relay code, but nothing.
To be honest I am completely stuck and not sure what to do from here.
The documentation for the board including sample C code can be found here:
http://www.freetronics.com/pages/relay8-8-channel-relay-driv er-shield-quickstart-guide
any help would be greatly appreciated and thanks in advance.
centrex
Posted: 11:18pm 29 Sep 2013
Probably a good idea to include your code so that we can see what you are doing. Are you using a external supply as recommended.
Cliff
Cliff
zcontrol
Posted: 12:10am 30 Sep 2013
Hi Cliff, since I am not currently driving any relays I am using the internal power supply and the plug pack is supplying 1.5amps at 9v, which is plenty.
As for the code:
10 I2CEN 100,1000
20 I2CSEND 32,0,1,128
30 Print MM.I2C
when I run this I get a 0 which means the command worked, but the decimal value of 128 on line 20 should enable all the relays?
The C code on the freetronics site for the Arduino version is a little more elaborate?
BobD
Posted: 12:20am 30 Sep 2013
That value of 128 in line 20 will only enable relay 8. If you want all on you have to add the values for each relay. You need a value of 255 for all relays.
zcontrol
Posted: 01:54am 30 Sep 2013
  BobD said   That value of 128 in line 20 will only enable relay 8. If you want all on you have to add the values for each relay. You need a value of 255 for all relays.
I did try 255 no go. irrespective of the value I add, non of the relay LED are lighting up. I even checked the physical voltage and nothing, so the board although it is ackowledging the command, its actually not doing anything with it.
jman
Posted: 09:01am 30 Sep 2013
Is there a circuit diagram for the shield ?
I suspect that the LEDs are driven by the same power supply as the relays.
So if the relays are not powered well you know the rest
zcontrol
Posted: 11:58am 30 Sep 2013
  jman said   Is there a circuit diagram for the shield ?
Hi John, refer to the link above in the first post for a diagram.
But please note that the shield defenitely has power, as the power LED is on, which means that it is ready to deliver power to the relays, assuming the board is instructed to do so!
Posted: 07:17pm 30 Sep 2013
The board has two power leds.
Green for VCC which supplies the relays and the relay LEDs
Blue for 5V supply.
I don't see any 5V regulator so you need 5 to 24V for VCC
and 5V regulated for the IC
Both Green and Blue LEDs need to be on for a working board.
jman
Posted: 09:22pm 30 Sep 2013
Yip I agree with Jim
Stick 12VDC on connector JP6 and I am sure the LED's will spring to life :)
John Edited by jman 2013-10-02
zcontrol
Posted: 10:09pm 30 Sep 2013
  TassyJim said   The board has two power leds.
Blue for 5V supply.
Jim and John, I can confirm that both the green and blue LED are lit and in fact I am getting an I2C return code of 0 from the above program which means I can successfully talk to the board, it just does not seem to actually switch the respective relays on.
At this stage I have to believe this is a software issue although I have not completely ruled out the hardware.
So to summarise:
1. Both LEDs are lit
2. I can successfully send I2C commands to the board
3. Board does not react as expected by switching on the respective relay
I can only assume that I am not sening through the correct I2C command or command sequence.
It would be great if someone could take a look at the Arduino code posted in the link above and come to some sort of conclusions regarding the commands that need to be sent via the I2C interface.
jman
Posted: 10:33pm 30 Sep 2013
Ok lets try this
Run the code below
Start:
I2CEN 100,100 ' Enable I2C
I2CAddr = &H20 ' this is the 23017 I2C address
' A2=A1=A0=0 <-> x100 000x
Init23017:
I2CSEND i2caddr, 0, 2, &H0A, &B10100000
I2CSEND i2caddr, 0, 2, &H0B, &B10100000
I2CSEND i2caddr, 0, 2, &H05, &B10100000
I2CSEND i2caddr, 0, 2, &H00, &B00111111
I2CSEND i2caddr, 0, 2, &H06, &B00111111
I2CSEND i2caddr, 0, 2, &H10, &B00000000
I2CSEND i2caddr, 0, 2, &H19, &B00000000
' End of Init
I2CSEND i2acaddr, 0 ,2, &H09, &HFF
Pause 500
I2CSEND i2acaddr, 0 ,2, &H09, &H00
End
Post the results
zcontrol
Posted: 04:22am 01 Oct 2013
John, my friend you are a genious.
The code posted above enabled the LEDs for relays 7 and 8 briefly and then switched them off again.
to be honest I was assuming that this line
would enable all the relays, but then again I had no clue to begin with!
Was the result what you expected?
The good news is, you have figured out how to get the board to do something!
jman
Posted: 07:58pm 01 Oct 2013
Hi
Glad to hear you had some success
Try this code
Init23017:
I2CSEND i2caddr, 0, 2, &H0A, &B10100000 ' Control Register Setup
I2CSEND i2caddr, 0, 2, &H0B, &B10100000 ' Control Register Setup
I2CSEND i2caddr, 0, 2, &H05, &B10100000 ' IOCON
I2CSEND i2caddr, 0, 2, &H00, &B00000000 ' IODIRA
I2CSEND i2caddr, 0, 2, &H09, &B00000000 ' GPIOA
I2CSEND i2caddr, 0, 2, &H10, &B00000000 ' IODIRB
I2CSEND i2caddr, 0, 2, &H19, &B00000000 ' GPIOB
Print MM.I2C
Start:
I2CSEND i2caddr, 0, 2, &H0A, &B10101010
Pause 1500
I2CSEND i2caddr, 0, 2, &H0A, &B01010101
Pause 1500
I2CSEND i2caddr, 0, 2, &H0A, &B00000000
GoTo Start
Led's should alternate 10101010 / 01010101
I have attached a link to the 23017 datasheet for you to take a look at
MCP23017 Datasheet
zcontrol
Posted: 10:24pm 01 Oct 2013
OK that did it, thanks John, I can start doing some useful stuff now! And thanks for the datasheet reference, I was wondering how you got to be so knowledgeable :) In my case without your guidance no amount of datasheets would have helped, hehehe.
Thanks Again.
