Forum Index : Microcontroller and PC projects : 4 years
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
Celebrating 4 years Dimitech and for a very short time - ICeemite from $19.95, DEB2-4105W40 at $0.95! If anyone has wondered what these small modules are, now it is a good time to find out. SHOP http://rittle.org -------------- |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1153 |
Hello Kon, that's a great offer! I would like to order 6x DTX2-4105C with MMBasic and 2x DEB2-4106W40. But..., how can I pay it over PayPal? Can you send me an advice of payment over PayPal? - or must I am registered in your shop? Thank you very much! Frank |
Hi Frank, You don't need to be registered, neither you need to have a Paypal account. Just hit the checkout button and follow the instructions on the page. When you get to Paypal's page depending on whether you do have an account or not, select the relevant option. Without a Paypal account you can use a few types of cards directly. If you have any problems, leave me a message or email contacts@dimitech.com Thanks, Kon http://rittle.org -------------- |
Hello Kon, I ordered it!
Firstly I had problems with the shipping address - it must be filled out, but there is no hint that this is necessary. I thought the normal address is automatically the shipping address... Thanks a lot! Frank |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10048 |
Any plans for one of these with the A0-A5 and D0-D13 ports? It's COM2(D0/D1) I really need, which does not seem to be standard on your beast... I fully appreciate and understand that you can't squeeze everything in! Schematic says that RTC can only be in software, so I guess that means there is no RTC chip per-Se', and that you perhaps use the PIC32's native internal clock? If so, does that mean you have a special version of MMBASIC? IE: Can you update with Geoff's firmwares, or does it have to be via you guys? (i expect the latter, if you are doing things the way I think you are) Smoke makes things work. When the smoke gets out, it stops! |
Geoff's original MMBasic works fine with one exception - it does not allow SD write operations. You can download V4.4/R6 which is customised for the module, has the RTC support and some other extras missing in the original MMBasic. It is backwards compatible with Geoff's version i.e. will work on any other MM mono clone as well. For the rest of your question - please check your private messages
Bryan1![]() Guru Joined: 22/02/2006 Location: AustraliaPosts: 2271 |
Hi Kon, Been that busy doing bathrooms I aint had time to spare for ages, now in your last post you said your version would work on any mono MM so is that the R6 version as I do have a couple here that would be good to try it on and having the help file will be the big bonus. Regards Bryan |
Hi Bryan, it's been a while since your last appearance. Glad to see you back. Yes, R6 should work fine with the other mono boards. Kon http://rittle.org -------------- |
Got your PM - thanks. Smoke makes things work. When the smoke gets out, it stops! |
Hi Kon, thank you very, very much for your fast delivery! I received your parcel today!
Many Greetings Frank |
You are welcome :) http://rittle.org -------------- |
