Local Time 03:19 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C
centrex
Posted: 01:00pm 03 Aug 2013
Can I connect multiple I2C devices to the same pins and will one set of pull up resistors only be req.
regards
cliff
Cliff
MOBI
Posted: 01:19pm 03 Aug 2013
That's the way the I2C bus works.
Just as long as the address for each device is unique.
David M.
BobD
Posted: 04:09pm 03 Aug 2013
More devices on the line increases the capacitance on the line. This may then force you to go to lower speeds and / or lower value pull-up resistors. See information on this here.
centrex
Posted: 04:45pm 03 Aug 2013
Many Thanks
Cliff
Cliff
