Local Time 03:26 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM: 3.3 v digital outputs
Juri74
Posted: 05:02am 16 Jul 2013
please a quick question:
i've to use digital outputs but with "ones" to 3.3v and not 5v, i mean when i use the command PIN(n)=1 and pin N change it state from zero to one it should have 3.3 volt, i do not remember which outputs to use... 11 to 20? or 1 to 10?
thank you
JuriEdited by Juri74 2013-07-17
Posted: 05:30am 16 Jul 2013
The outputs are always 3.3 volt.
5v is only important when you use it as an input. Then the pins have to be 5v tolerant otherwise you can damage the PIC32 chip.
relevant part from the manual:
[quote]
The original Maximite has 20 I/O pins numbered 1 to 20. Pins 1 to 10 can be used for analog input and digital
input/output with a maximum input voltage of 3.3V. Pins 11 to 20 are digital only but support input voltages
up to 5V and can be set to open collector.
The DuinoMite has completely different and confusing allocations. See "DuinoMite MMBasic ReadMe.pdf"
Normally digital output is 0V (low) to 3.3V (high) but you can use open collector to drive 5V circuit. This
means that the pin can be pulled down (when the output is low) but will go high impedance when the output is
high. So, with a pull up resistor to 5V an output configured as open collector you can drive 5V logic signals.
Typical value of the pull up resistor is 1K to 4.7K.
[/quote]
Juri74
Posted: 06:35am 16 Jul 2013
thank you TZA, i missed that info!
djuqa
Posted: 01:25pm 16 Jul 2013
And despite what most here call them the outputs are OPEN DRAIN not open Collector so normal MOSFET handling/current limits apply.Edited by djuqa 2013-07-17
VK4MU MicroController Units
Posted: 07:56pm 16 Jul 2013
I have a rather poor understanding of what those "normal" limits are - please explain or can you provide a URL of somewhere with a summary?
dergi
Posted: 06:35am 07 Aug 2013
Normal MOSFET handling/current limit...interesting. I don't really know what normal current limit for MOSFET is. I am really interested inlearning about it if someone is willing to help. @TZAdvantage: Thanks for the clarification, that was helpful.
smt assembly Edited by dergi 2013-08-13
