Local Time 03:07 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Big Bug in Random Access
marcwolf
Posted: 07:31pm 14 Jul 2013
Hi.
I was working with some random access files and I think have found a fairly major bug (Sorry Grahame)
The PRINT #1 command adds a CRLF at the end of the line. So if we have 3 records all 6 bytes long and we use the SEEK command to move to record 2 and change it's value using the PRINT then we will write 6 + 2 (CRLF) characters into the file and thus kill the first 2 bytes of record 3.
If you could change the WRITE command NOT to add the CRLF then we can use that.
i.e. original
111111222222333333
Change rec in middle (222222 to 444444)
111111444444xx3333 where xx is CRLF
Hope this helps
Dave
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
Posted: 07:47pm 14 Jul 2013
A semicolon (;) at the end of the expression list will suppress the
automatic output of a carriage return/ newline at the end of a print
statement.
marcwolf
Posted: 08:06pm 14 Jul 2013
Phew.
Many thanks for that Jim.
Dave
RAW CODE!!!!!
paceman
Yes, and Appendix I (page 60) of the updated Manual for V4.4 gives the rundown.
