Local Time 03:07 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit and new/custom commands
marcwolf
Posted: 05:39pm 14 Jul 2013
Hi
As Geoff brings out new version of MMBasic is there anyway we (the users) can add new commands to MMEdit without needing to wait for a new version.
For example 3.3.7 does not recognise the SEEK command.
Also as some of us are creating our own functions it would be nice to add them in as well.
Many thanks
Dave
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
Posted: 06:20pm 14 Jul 2013
I will have the updated commands done in a few days.
I also need to check the new commands to see if I have to do anything for the auto-indent.
For your own commands:
go to Help\edit syntax help
On the right, just beside the quit button, select "edit user syntax"
Any commands you add here will not get overwritten with MMEdit updates.
If you don't like one of the standard helps, you can add your own version here and it is the one that gets displayed.
Do this in the user help or it will get overwritten with updates.
(Page 14 in the MM Edit help file)
JimEdited by TassyJim 2013-07-16
