Local Time 03:06 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : The official definition of Arduino board
vasi
Posted: 05:19am 12 Jul 2013
and the derivative work of others
http://blog.arduino.cc/2013/07/10/send-in-the-clones/
Elvish name: Mablung Miriel
Beyound Arduino Lang
Dylan
Posted: 09:27am 12 Jul 2013
Clones are good for the ecosystem. Derivatives are even better - in theory at least.
"Compatibles" is indeed hazy. I bought a Duinomite on the basis of this, but the added feature I wanted - USB OTG - simply does not exist.
Counterfeits are, of course, right out. It is one thing to clone open hardware and even use the same USB ids, quite another to stomp the Arduino trademark.
But all works are derivative. MMBasic relies on Pic32 libraries and the Lucio di Jasio's book, for example. I'm not too impressed by Arduino's additional offset between digital pins 7 and 8. No problem with the designers' wish to make a profit/keep a job, but a sad decision all the same. Not that I need more than 2 PWMs now, but some day I might want to have six without buying a board marked up by over 1000% for what I want.
vasi
Posted: 10:51am 12 Jul 2013
Once you transformed an open-source project (made/invented by Hernando Barragan which is not part of Arduino team) into a commercial one, you will start doing any other commercial firm is doing.
I've posted a comment there, waiting for moderation for awhile but is not available any more, I guess it was deleted. See the image bellow:
Screenshot - 07122013 - 07:05:59 PM by funlw65, on FlickrEdited by vasi 2013-07-13
psergiu
Posted: 10:56am 12 Jul 2013
  Dylan said   I'm not too impressed by Arduino's additional offset between digital pins 7 and 8. No problem with the designers' wish to make a profit/keep a job, but a sad decision all the same.
The Arduino designers admitted it was a mistake - someone edited the final gerber before the first production run to fix a bug and accidentally shifted that header. No one noticed until they got them back from the factory. As the 1st Arduino boards were originally intended for use only for that faculty course, they left it like that. And after it gained too much popularity, they couldn't change-it back as it would have broken backward compatibility.
Same with RaspberryPi's USB port connector being misaligned with the ethernet port - It was originally designed for a shorter USB connector but they found out later that the longer USB connectors were 1/2 of the price. They used the cheaper ones but couldn't shift the mounting holes back on the board as the design was already "set in stone" after it passed all the CE tests.
Posted: 10:58am 12 Jul 2013
  Dylan said  I bought a Duinomite on the basis of this, but the added feature I wanted - USB OTG - simply does not exist.
I think you mean that MMBasic / DMBasic support for it doesn't. The hardware looks fine - or is it not?
vasi
Posted: 11:08am 12 Jul 2013
Hi Sergiu,
I read that excuse too, but they had the chance to repair that before going to mass production as is today. If you want a development board for students with low finances (and every one knows that a student is low on money every time), then you do the right thing - repair the design for breadboard shields. So nope, I don't believe them. Hernando Barragan did the right board before Arduino going commercial so they had an example and a lot of time for thinking. They did that intentional or it was a happy "mistake". So I think that their confession is a "weird" excuse at least.
Dylan
Posted: 10:46am 13 Jul 2013
John, USB OTG support on the chip is not the issue. Duinomite has a Mini-B and my phone has Micro-B. I want the Duino side to be AB.
But maybe I am missing something obvious.
Posted: 04:25am 14 Jul 2013
Can't you just plug it in? Are any signals missing? Although if it lacks software how would you know it works?
Dylan
Posted: 05:41am 14 Jul 2013
Since Mini-B--Micro-B cables don't exist, I've bought adapters for both (with female regular A).
I see now (http://tzblox.com/PublicDocuments/ReferenceManuals/Microchi p/PIC32%20Family/PIC32%20Family%20Reference%20Manual%20-%20S ection%2027%20USB%20On-The-Go%20-%2061126F.pdf, thanks for putting them in order!) that I probably need to set VBUSON in U1OTGCON to get power. A lot more needs to be done to actually get a signal, so I'm working around this completely.
But yeah, learning a lot ;)
