Local Time 03:00 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Disable an interrupt?
Posted: 05:10pm 08 Jul 2013
Hi all.
Still playing with my interrupts.
Once you have set one up on the COM port, how do you temporarily disable it?
The manual, page 7, right at the bottom says: "Also remember to disable an interrupt when you have finished needing it - background interrupts can cause strange and non-intuitive bugs."
...we will say nothing of the other problem I was having...(DO/LOOPS thread)
Anyhow, in the case of the serial port, do I just CLOSE the port, and the interrupt is then disabled?
I am guessing this is the way to do it, but as I have made assumptions like this before, I thought I should ask.
So, I would assume that if I close the port, the interrupt will be cancelled, as there is no valid open port for it to work with once the port is closed.
I can then just re-open the port again with the interrupt when I need it - correct?
Posted: 07:15pm 08 Jul 2013
  Grogster said  So, I would assume that if I close the port, the interrupt will be cancelled, as there is no valid open port for it to work with once the port is closed.
Yes, that is exactly correct.
P.S. It is a change to see others creating bugs rather than me.
