Local Time 03:06 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 4 Bit reorder
jman
Posted: 12:14am 03 Jul 2013
Hi
I working a little project that I need to reorder a 4bit nibble
for example (1-4 2-3 3-2 4-1)
In Out
0001 1000
0010 0100
0011 1100
0100 0010
1000 0001 etc...
I am sure you smart people that hang around here have
a simple way of doing this ?
Edited by jman 2013-07-04
kiiid
Posted: 12:54am 03 Jul 2013
I am sure there is a mathematical way, but for 4-bit numbers, that's 16 values only. A lookup table would do the job easily
http://rittle.org
MOBI
Posted: 02:03am 03 Jul 2013
What platform/language are you using e.g. PIC, AVR, PC? Assembly, C, VB??
David M.
jman
Posted: 02:04am 03 Jul 2013
Maximite Basic 4.3
ajkw
Posted: 02:07am 03 Jul 2013
byte = 19566 ' sample 0100110001101110
for i = 15 to 0 step -1
newbyte = newbyte + ((2^(15-i)) * ((byte AND (2 ^ i)) > 0))
next i
print newbyte ' Should return 30258 being 0111011000110010
2 little changes required for 4 bits instead of 16 as in the example.
From Topic
http://www.thebackshed.com/forum/forum_posts.asp?TID=5420&KW =swap+bits&TPN=3
Sample code only, make sure you do your own error testing and that it suits your purpose!
Dylan
Posted: 05:46am 03 Jul 2013
I agree with Kon that a look-up table is the way to go.
ajkw has a workable solution, but given that Maximite has 32-bit float arithmetic, performing 8 (let alone 32) ^ operations might not be what you want.
r = (b AND 1) * 8 + (b AND 2) * 4 + (b AND 4) * 2 + (b AND 8) * 1 ' is versatile, 11 ops.
Divide and conquer (a la http://stackoverflow.com/questions/9144800/c-reverse-bits-in -unsigned-integer):
x = (x\2 AND 5) + (x AND 5)*2 ' 5 ops;
x = (x\4 AND 3) + (x AND 3)*4 ' saves an operation, but adds an assignment.
RTFineM: http://geoffg.net/Downloads/Maximite/MMBasic%20Language%20Ma nual.pdf (page 14)
Function Bit(nbr, bit)
If nbr < 0 or bits < 0 THEN ERROR "Invalid argument"
Bit = (nbr\(2^bit)) AND 1
End Function
x = Bit(x, 3) + Bit(x, 2) * 2 + Bit(x, 1) * 4 + Bit(x, 0) * 8 ' or vice versa!
Mathematical way:
http://en.wikipedia.org/wiki/Cooley%E2%80%93Tukey_FFT#Data_r eordering.2C_bit_reversal.2C_and_in-place_algorithms
http://en.wikipedia.org/wiki/Bit-reversal_permutation
Both of which are shotguns for gnats. ;)
Posted: 06:42am 03 Jul 2013
I also prefer a table. They are quick, and easy to understand and maintain.
Al those fancy calculations are just mental exercises, they don't gain much in an interpreted language and most are not even faster when used in assembly.
If someone else looks at your code, he would probably think, what a show off. Just get it done.
And there are so many ways to get it done, even with lookup tables.
You can even make it with an on nbr goto statement. Oh the horror.
I prefer to look at a piece of code and see what it is doing without having to step through it line by line with a calculator and check for open and close braces to get the order. Double horror.
Just make a table of numbers, fill it one by one when there are not much numbers or use a for next loop to read DATA. If it is a big lookup table store it in a file.
It scales very well and you can even use it in many other instances where it is not only a reversal of bits.
After that it is just B = Translate(A)
Edited by TZAdvantage 2013-07-04
Dylan
Posted: 07:13am 03 Jul 2013
XLAT (http://en.wikipedia.org/wiki/X86_instruction_listings)
ajkw
Posted: 05:26pm 14 Jul 2013
Just in case someone searches the forum and finds this thread
I liked the look of this
  Quote  r = (b AND 1) * 8 + (b AND 2) * 4 + (b AND 4) * 2 + (b AND 8) * 1 ' is versatile, 11 ops.
but it does not work.
eg: 2 and 2 = 2 not 1. (2 and 2) * 4 = 8 (not 4 like it needs to be)
so a little change to
r = ((b AND 1)>0) * 8 + ((b AND 2)>0) * 4 + ((b AND 4)>0) * 2 + ((b AND 8)>0) * 1
does work.
No ^ ops, no for/next loops, 1 line, but has braces and will get cumbersome for 8 let alone 16 or 32 bits.
I wonder how John got on??
Posted: 08:33pm 14 Jul 2013
I like oneliners for the sport of it, and being unclear is mandatory. :)
This one reverses a nibble. :)
Is this the shortest?
It does only 5 operations so it should also be fast.
[code]
r = ASC(MID$("084<2:6>195=3;7?",(b AND 15) + 1,1)) AND 15
[/code]
it is essentially only a lookup table, the use of mid$ is specific for basic as it does not have a byte array.
This can easily be changed to 8 bits.
It would be easier to define the lookup string separate.
[code]
l$ = "................" 'fill with characters that translate the input character
r = ASC(MID$(l$,(b AND 255) + 1,1))
[/code]
Edited by TZAdvantage 2013-07-16
Posted: 09:42pm 14 Jul 2013
I like the idea of using MID$
Arguably a more readable version would be to use printable characters people generally know, though it's complicated by wanting to keep the code short.
ASC("@") is 64 (binary 0100 0000), so lots of low zero bits, and from there on we have "ABCDEFG" (etc).
I think this gives
new = ASC(MID$("@HDLBJFNAIEMCKGO", nibble + 1, 1) AND 15
As a quick check, we're reordering the numbers 0 to 15 so there should be 16 consecutive chars of the character set but shuffled, which there are ("@ABCDEFGHIKLMNO").
Posted: 10:16pm 14 Jul 2013
I like the more readable range of "@ABCDEFGHIKLMNO"
I picked the range i used because it has the 0123456789 in it so that at least 10 of the 16 will have the right visible value.
1 becomes 8, 2 becomes 4, 4 becomes 2 etc.
Maybe
@HDLBJFNAIEMCKGO
mixed with
084<2:6>195=3;7?
becomes
084L2J6N195M3K7?
It adds to the obscurity and is a better puzzle for ones trying to figure it out.
