Local Time 02:51 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SPI question
vk4tec
Posted: 06:05pm 28 Jun 2013
Hello
I had a max7910 working with a 8 digit 7 seg led display with duinomite
I now intend to use maximite mini instead
Are the commands likely to be the same ?
For SPI comms ?
Andrew
Andrew Rich VK4TEC
www.tech-software.net
MM_Wombat
Posted: 01:55pm 29 Jun 2013
Andrew,
Short answer --Yes..
After looking at the MMBasic program from this Thread you wrote.
I used 3 Austria Microsystems AS1107 to control 3 8x8 led displays, my MMBAsic program is on this thread . Coded for a Mono MM. Very similar, but mine displayed text.
Dennis
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
