Local Time 09:06 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS1302 RTC
vk4tec
Posted: 02:26am 28 Jun 2013
Hello
I have the DS1302 RTC working on my QL200 board 16F877A
I also have the time being shown on a 6 x 7 segment display HH.MM.SS
Here is an overview of what happens
DS1302 RTC
1. Define three pins - I_O, SCLK and RST
2. Set an address start address to hold time to send and time to read
3. Initialise ports
4. Load up the initial time - to send to RTC
5. Set the time - in multi byte mode ( not just one by one ) sending 8 bytes ROLL RIGHT
6. Manage the pins for the RTC by manipulating the lines one bit at a time
7. Get the time - similar to set time, but this is get time, 7 bytes this time.
8. Use a look up table to form the segment of the 7 segment display
9. Send Hour Minute Second to the 6 x 7 Segment display HH.MM.SS
loop - get time and display
I need to work out how to get the GPS into the equation now .
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
