Local Time 09:06 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM Gulp Strange Symbols!
Nixie
Posted: 03:27am 21 Jun 2013
Well I just built a Colour Maximite, updated it to Colour Maximite MMBasic 4.3A
And this is what happens with the following:
A simple program (ok it does 'flicker' on the Mono MM too)
THIS...
10 CLS
20 ? Time$
30 GOTO 10
GIVES....a running clock
20:31:19
[2J[H ....but also with this on the CMM?!
ALSO when I try and run an 11 k program I have written, which runs beautifully on the
Mono MM; it doesn't get past first base!? Giving me the following:
>Run
[2J[H. (Here it is again!)
10 Cls ' file name 15M_PB1H.BAS. (This is just a REM line)
Error invalid syntax
Any Clues Please? Thanks, Nic.
(I'm already bald so don't know what happens next ! )
Posted: 03:42am 21 Jun 2013
[2J stands for clear screen.
[H means position the cursor at the home position
Here is a list of all those command: http://bluesock.org/~willg/dev/ansi.html
This means you are using the MM through a terminal, right?
When that happens your terminal program has a problem interpreting those codes when they come too fast..
They are called ANSI codes and are used to control terminals cursor position, colors etc.
If the MM is too fast for your terminal. Try slowing it down.
if you want a clock that updates every second you could do this:
[code]
'Every second
SETTICK 1000, ShowTime
'Endless loop until a key is pressed
DO WHILE INKEY$ = "": LOOP
ShowTime:
CLS
? TIME$
IRETURN
[/code]
Edited by TZAdvantage 2013-06-22
Nixie
Posted: 03:52am 21 Jun 2013
Er no not using it through a terminal!
Just a new Colour Maximite with only the screen, keyboard and 9 v power supply plugged in.
Gulp?!
Yes on the clock. I appreciate the code. Thanks.
Posted: 04:15am 21 Jun 2013
If you use a VGA or Composite then that should not happen.
Maybe a bug in MMBasic.
You could try the newer version currently in beta and see if the problem is solved.
Here is the topic about that:
http://www.thebackshed.com/forum/forum_posts.asp?TID=5828&PN =1&TPN=1
Nixie
Posted: 04:35am 21 Jun 2013
Thanks for the suggestion. I'm using a VGA.
Will try the beta software tomorrow.
Juri74
Posted: 05:20am 21 Jun 2013
Hello Nic,
i tried some minutes and i confirm, i used v4.3a
the bug is in the "cls" command, try:
Cls
Loop
Juri
Posted: 05:48am 21 Jun 2013
does it also occur with a delay?
[code]
do
cls
for l=1 to 1000:next
Loop
[/code]
Try changing the value 1000 into higher and higher values and see if the bug goes away.
Posted: 12:20pm 21 Jun 2013
In the CLS routine it sends the VT100 clear screen command to the console so that a terminal emulator, if connected to the USB port, has its screen cleared. The CLS routine then clears the video memory which should erase these codes.
How the codes remain on the video screen I don't know... I will investigate.
Thanks, Geoff
Nixie
Posted: 03:32pm 21 Jun 2013
TZAdvantage - I have updated to 4.4 beta and still have the same problems.
JURI - same thing with 4.4 beta - with your example code
TZAdvantage - no it doesn't show the VT100 code if I introduce a delay! But that isn't soling the issue, merely hiding it
UPDATE ON PROGRAM CRASH!
CLS
? date$;" "; time$
End
WORKS FINE........BUT:
CLS ' placing a REM IN HERE WELL MAKES THE PROGRAM CRASH.
? date$;" "; time$
End
AH HA !
However, if I put a colon after CLS, (CLS: ' REM) the program above runs fine
And if I do the same to my code in my 11 K program (mentioned above), it also works fine!
Yahoo! ....well at least I can work around the CLS cmd!
GEOFF - I guess over to you. Thanks again for you efforts.
..and thanks to all for reading and offering suggestions. Cheers Nic.
Posted: 02:11am 22 Jun 2013
Geoff,
If i quickly and repeatedly press the up arrow key i also get the VT100 code in the screen. However that is very rare.
Maybe the same issue. And i remember it also occurred sometime with the function keys.
panky
Posted: 05:03pm 22 Jun 2013
Geoff,
I too have seen the up arrow ( and down arrow ) problem on a CGCMM1 running 4.3 with extraneous characters appearing when repeatedly pressing the keys. Easy to miss and a bitch to debug - when you are proofing a program, the eye sometimes tells the brain what it expects is there rather than what is realy there.
Cheers, Doug.
Posted: 05:10pm 22 Jun 2013
This is something that I have not been able to fix (so far). It only happens when the USB is connected and seems to be caused by Tera Term echoing a character back to MMBasic.
And, yes, it is a pain when it happens.
