Forum Index : Microcontroller and PC projects : Whos who ?
| vk4tec Senior Member Joined: 24/03/2012 Location: AustraliaPosts: 239 |
Who works on mm basic ? And the pc version ? Testers ? Hardware ? Andrew Andrew Rich VK4TEC www.tech-software.net |
| shoebuckle Senior Member Joined: 21/01/2012 Location: AustraliaPosts: 189 |
Why do you ask? Hugh |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6608 |
If you mean who developed the Maximite, the answer to all the above is "Geoff" I suggest that you read the details on his web site: http://geoffg.net/maximite.html There has been input from others and they are acknowledged in Geoff's articles. Jim VK7JH MMedit |
| BobD Guru Joined: 07/12/2011 Location: AustraliaPosts: 935 |
The copyright command may give you some of what you want. As well as the usual copyright stuff it acknowledges some of the people who have made contributions. |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2981 |
Andrew, If you mean who USES or did some of the following then: Me (a bit) Not Me ... Never ever looked at it... With DM In the dark days (dont mention the war).... ME Me. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
Leaving the cult to Geoff aside, I would mention that I am doing a bit of work on this as well. You can download my current revision of the MMBasic from HERE Unfortunately not everyone gets lucky to be mentioned in the Geoff's articles... http://rittle.org -------------- |
| djuqa Guru Joined: 23/11/2011 Location: AustraliaPosts: 447 |
You do realise that all versions of MMBASIC after 2.7 are NOT OPEN SOURCE Geoff's source , geoff's rules He has made it widely known plain and simple [quote]Source Code - Personal Use The source code to MMBasic is Copyright 2011 - 2013 Geoff Graham and may be used for an individual's personal use under the following terms: The files may not be distributed or made available to others without specific written permission. Object files (ie, .o, .exe, .hex files) generated using one or more of the source files (modified or not) are for personal use only and may not be distributed without written permission. The files are provided without any warranty; without even the implied warranty of merchantability or fitness for a particular purpose. [/quote] VK4MU MicroController Units |
Was that for me? I stick to the rules and Geoff knows it. http://rittle.org -------------- |
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1134 |
Konstantin, I like the idea of your modules but I am curious as to why you need a special version of MMBasic rather than feed suggestions/ideas back thru Geoff?
I have a Duinomite from Olimex and again, while a great idea and feature advancement on the original MM, it's non standard features made it a PITA ( pain in the #$%). It would be great to develop/debug on a full feature MM ( eg. CMM ) then transfer to your DTX for final use, however, if there are differences in the 2 Basics? Frustration. Regards, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Doug, The module is FULLY compatible with the original MMBasic. That means you it can run it directly from the Geoff's archive (I have even posted a Youtube video with it) and vice versa - my version will work on the standard Maximite. The additions I have made are only on top of the original MMBasic plus the hardware support of the RTC chip which is missing in the Maximite and is different in the CMM. Some ideas that I suggested to Geoff in private correspondence I see he has already adopted in the standard version, others remain in mine only (like the unlimited number of files DIR and the new INIT command, as well as other little things). But apart from the RTC, the whole hardware is 100% compatible with the Maximite, unlike the Duinomite. Konstantin http://rittle.org -------------- |
