Local Time 02:40 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Local variable size limit
BobDevries
Posted: 03:39pm 21 May 2013
Hi all,
is there a limit toi the size of LOCAL variables in functions?
I'm getting an error: stack overflow. Expression is too complex.
The code:
Function fkey(funkey)
Local F$,I$
F$=Chr$(145)+Chr$(146)+Chr$(147)+Chr$(148)+Chr$(149)+Chr$(15 0)+Chr$(151)
F$=F$+Chr$(152)+Chr$(153)+Chr$(154)+Chr$(155)+Chr$(156)
key: I$=Inkey$:If I$="" GoTo key
funkey = Instr(1,F$,I$)
Return
What am I doing wrong?
Bob Devries
Dalby, QLD, Australia
BobD
Posted: 03:49pm 21 May 2013
Typo?
Chr$(15 0)extra space
should that be Chr$(150) ?
BobDevries
Posted: 03:53pm 21 May 2013
Hi Bob,
I checked that, but it seems to be an artifact of cutting and pasting into the forum.
There's no space in my code.
Bob Devries
  BobD said   Typo?
I would expect that that problem would be the infamous `The Bad Shed' Add extra spaces to long lines (that arent broken by a space)
BobDevries
Posted: 04:08pm 21 May 2013
Hi All,
even if I remove the line that declares the LOCAL variables, I then get the same error on the line:
key: I$=inkey$:if I$="" then goto key
Have I unearthed a (dare I say it?) bug? Or am I doing something basically (pun intended) wrong?
Bob Devries
paceman
Posted: 05:08pm 21 May 2013
Bob, I think I had this problem some time ago - try putting the label on a separate line,
key:
I$=inkey$:if I$="" goto key
Greg
BobDevries
Posted: 05:10pm 21 May 2013
Ah, now that you mention it....
I'll give that a try.
Bob Devries
BobDevries
Posted: 05:17pm 21 May 2013
Hi Greg & all,
Yep, that works now.
Strange thing is... if I put the same line as inline in the main body of the programme, no error is generated. Go figure.
Bob Devries
Posted: 05:28pm 21 May 2013
Bob,
This is the first time that I have seen someone hit the "stack overflow" error. It is not caused by a local variable being too big - local variables have exactly the same rules as normal variables.
What happens is that the interpreter evaluates an expression by recursively calling itself and while doing that it saves temporary values onto the stack. The stack overflow error means that the expression is so complex that the interpreter has used up all the RAM reserved for the stack.
The problem here is that the expressions in the sample program are not nearly complex enough to cause this error. Also the loop at the label "key:" could not be causing a stack overflow because there is no complex expression there either.
I tried running the program but it does not run and it does not make any sense. You declare a function but there is no END FUNCTION statement, instead you use RETURN when there is no GOSUB to return to. I suspect that it is this mangled code that is somehow tripping up the interpreter which then runs off the rails causing the stack overflow error.
paceman
Posted: 06:14pm 21 May 2013
  Geoffg said  Bob,...... You declare a function but there is no END FUNCTION statement, instead you use RETURN when there is no GOSUB to return to. I suspect that it is this mangled code that is somehow tripping up the interpreter which then runs off the rails causing the stack overflow error.
That's probably what I was doing too Geoff. At the time I remember I'd mixed up various combinations of "GOSUB", "FUNCTION", "END FUNCTION", "RETURN" and labels (no ":" on them) a couple of times before I fnally got the code working.
Greg
BobDevries
Posted: 06:24pm 21 May 2013
The final code which works is here:
Function fkey()
Local F$, I$
F$=F$+"Q"+"q"
key:
I$=Inkey$:If I$="" Then GoTo key
fkey=Instr(1,F$,I$)
End Function
@Geoff:
You're probably right about what really caused the error. I had mixed up the function/end function with Gosub/Return.
I'd say the interpreter got confused; I know I was :P
Bob Devries
