Local Time 02:28 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM doesn’t show in Device manager WinXP
BobDevries
Posted: 02:49pm 20 May 2013
Hello all,
I just upgraded to MMBasic 4.4B1.
I don't know if it's a result of the upgrade, but the MM (original mono) no longer shows up as a serial port in Device manager.
It works fine when plugged into a monitor.
Any one know what could cause this behaviour? It did work before.
Bob Devries
Dalby, QLD, Australia
BobDevries
Posted: 03:26pm 20 May 2013
Further details...
I usually plug the MM into the PC via a USB hub. If I plug it in directly to a USB port on the computer, it works fine, but not on the hub.
Comments?
Bob Devries
James_From_Canb
Posted: 06:01pm 20 May 2013
Bob,
That sounds similar to a problem I had earlier in the year. Try clearing unused com port allocations by the method TZ found. It's in thread Tbs link
James
