Local Time 02:41 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 3.3 volts
vk4tec
Posted: 11:06pm 19 May 2013
Guys I am using a LM317
To go from 11 volts to 3 volts
Runs hot.
Do they make small switch mode regs ?
One guy suggested mobile phone charger to get from 12 down to 5 then go 3 volts
Andrew
Andrew Rich VK4TEC
www.tech-software.net
kiiid
Posted: 11:38pm 19 May 2013
Andrew,
You might want to consider some SimpleSwitcher from TI. I have used LM2595 many times and they run very well.
KonEdited by kiiid 2013-05-21
http://rittle.org
Posted: 02:03am 20 May 2013
Could be worth a look at the schematics on the Olimex site. They use all manner of chips & voltages. All open hardware.
jman
Posted: 09:38am 20 May 2013
Hi
I have used lots of these
DC-DC
Great price
Posted: 03:22am 22 May 2013
What about this one:
http://ww1.microchip.com/downloads/en/DeviceDoc/22008E.pdf
They are about 1US$.
johnbig
Posted: 08:47pm 22 May 2013
Hi Andrew. How about the 1.2 to 20 volt switching regulator at 1.5 amps in Silicon Chip Feb 2012 with no heat sink.
John Leate
hakantok
Posted: 06:56am 10 Jun 2013
The LM1117-N is a series of low dropout voltage regulators with a dropout of 1.2V at 800mA of load current. The pin-out is similar to industry standard LM317. It is available in five fixed voltages 1.8V, 2.5V, 2.85V, 3.3V, and 5V.
bga assembly Edited by hakantok 2013-06-18
